20 Most Recent Hamilton Beach 48274 BrewStation 6-Cup Coffee Maker Questions & Answers
Brewstation sounds like its boiling coffee after it's finished
It sounds like the sensor that switches from brew to keep warm is faulty... so it keeps boiling after it's brewed. My suggestion to you is to clean it it with vinegar. The following link shows how to clean a ten-cup model. Just use smaller amounts for the six-cup model. Good luck https://youtu.be/mdigGqyI6iw
1/7/2020 2:06:22 PM • Hamilton Beach... • Answered on Jan 07, 2020
2answers
I am interested in purchasing this 6 cup brew
How does the coffee get into the cup? If it brews directly into the cup then the amount can be controlled by how much water you put into the maker. If it is a 6 cup then it must hold the coffee in a reservoir. Do you have to push and hold a button to dispense the coffee or do you push and wait for it to fill your cup? If it is the latter then it will need to know how large or small the cup size is. Is there a setting for that? If it is a push and hold method then you control the coffee flow so size is up to you. As far as it being a travel mug or ceramic mug as long as the mug will fit in the maker and sit securely under the nozzle then it shouldn't matter what kind of mug it is.
11/2/2011 7:38:45 PM • Hamilton Beach... • Answered on Nov 02, 2011
Can't work coffee maker HELP ME PLEASE
Your Use and Care Manual is available here:
http://useandcares.hamiltonbeach.com/files/840163603.pdf
You didn't state a specific problem.:
Go to page 5 for instructions on how to make coffee.
Got to page 8 for help with Troubleshooting.
2/2/2011 6:17:06 AM • Hamilton Beach... • Answered on Feb 02, 2011
For a HamiltonBeach Brew Station 12 cup
You can, you need to contact hamilton beach to get a new filter, it sounds like that one is shot for sure. Their number is 800-851-8900. You should be able to just hit 0 when the recording picks up and get to a live person. Although it may be too late tonight still.
Tim
10/9/2010 1:13:58 AM • Hamilton Beach... • Answered on Oct 09, 2010
How much coffee do i add into a Hamilton Beach
You may add 6 tsp of coffee powder or two coffee beans if u have a grinder
thanks
5/20/2010 5:27:44 AM • Hamilton Beach... • Answered on May 20, 2010
2answers
How do you get the
I made a video just for you and put it on the web on you tube.
http://www.youtube.com/watch?v=7dkk8jSClik
5/5/2010 2:47:01 PM • Hamilton Beach... • Answered on May 05, 2010
2answers
Hamilton beach flexbrew. Say “Fill H2O” but is is full. What do I do?
I was able to fix this:1. Remove top cover2. Remove grate, one screw3. Dump water4. Clean water sensor probe (silver colour, bullet shape, approx 1/4" long), use a small flat screw driver with paper towel to remove any build up.5. Plug in and test until it works.if you get it to work again, that would be a good time to run the vinegar solution through.
1/19/2023 6:28:09 PM • Hamilton Beach... • Answered on Jan 19, 2023
The coffee dispenser bar isn't working in my Hamilton Beach coffeepot 47900. Nothing comes out! Can I fix it?
There are a few possible reasons why the coffee dispenser bar on your Hamilton Beach
  1. Check the water level in the reservoir. Make sure that there is enough water in the reservoir to brew a full pot of coffee. If the water level is too low, the coffee dispenser bar may not work properly.
  2. Clean the coffee dispenser bar. Over time, coffee grounds and other debris can accumulate on the coffee dispenser bar, clogging it and preventing the coffee from flowing properly. To clean the bar, run a solution of equal parts water and vinegar through the coffeepot and then rinse it thoroughly.
  3. Check the filter basket. Make sure that the filter basket is properly seated in the coffeepot and that it is not clogged with grounds. If the basket is not properly seated or is clogged, it may prevent the coffee from flowing through the dispenser bar.
  4. Check the gasket. The gasket is a rubber seal that helps to create a tight seal between the carafe and the coffeepot. If the gasket is damaged or worn, it may cause a leak and prevent the coffee from flowing through the dispenser bar.
If none of these troubleshooting steps resolve the issue, it is possible that there is a problem with the coffeepot itself. In this case, you may need to have it repaired or replaced.
1/7/2023 8:26:12 PM • Hamilton Beach... • Answered on Jan 07, 2023
2answers
My Hamilton beach flex brew says add water when full and will not work
Push "Carafe" button.
12/23/2022 9:06:23 PM • Hamilton Beach... • Answered on Dec 23, 2022
Hamilton Beach coffee grinder 80365
Try tapping the other way. You may have unseated the motor's carbon brushes. or Send it back under warranty. https://hamiltonbeach.ca/customer-service ..
9/4/2022 9:55:24 PM • Hamilton Beach... • Answered on Sep 04, 2022
Hi, I just purchased a Hamilton Beach Brewstation . After brewing the coffee it sounds like the coffee that is being kept warm is boiling ? What is causing this ? It’s very loud and doesn’t seem normal ??? Please let me know? Ty
Mine does the same. Very annoying and the unit is 3 months old. I cleaned the unit yesterday and no help. I'll call HB today and see if they can help.
4/1/2022 12:31:19 PM • Hamilton Beach... • Answered on Apr 01, 2022
How do I know when my Hamilton Beach flex brew coffee maker is turned off? No lights appear to indicate on/ off
Normally there are no lights which does signify off. To check, disconnect from the mains electricity supply for 5 minutes and plug back in. https://www.google.com/search?q=hamilton+beach+flexbrew+coffee+maker+manual ..
12/2/2021 5:56:43 AM • Hamilton Beach... • Answered on Dec 02, 2021
2answers
Hamilton beach flex brew has turned on twice now with no program set. Very Dangerous. What can we do?
Report this potentially dangerous defect to Hamilton Beach.
12/1/2020 3:46:34 PM • Hamilton Beach... • Answered on Dec 01, 2020
My Hamilton beach 80335R grinder does not turn on. Only used it 3 times. Outlet is fine (tested it) Was a Christmas present.
Take to the store where it was purchased and have it replaced. Warranty Get receipt.
1/9/2020 8:54:02 PM • Hamilton Beach... • Answered on Jan 09, 2020
2answers
I have a hamilton beach coffee maker and the tank seal has came loose. I got it taken apart but now I can't get the seal in place. Someone please tell me there is an easy way.
Easy way is to get online or go down to your favorite store and buy a new coffee maker.
3/5/2019 4:46:59 AM • Hamilton Beach... • Answered on Mar 05, 2019
Hamilton Beach 48274 BrewStation 6-Cup Coffee Maker Logo
17 questions posted
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
Marvin
Marvin
ADMIN Andrew
ADMIN Andrew
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Hamilton Beach Coffee Makers & Espresso...
  • Hamilton Beach Coffee Makers & Espresso...
Most Popular Question
hamiltonbeach brew station 12 cup
  • Coffee Makers & Espresso Machines
