20 Most Recent
General Electric PEB1590SMSS Stainless Steel 1000 Watts Convection / Microwave Oven Questions & Answers
Get F3 warning on panel.
where
Error code F3 on many models of
microwave oven means a problem with the touch panel, (tact switches).
Replace the switch panel to fix the
fault.
Hope this helps.
GE PEB1590 microwave oven. Interior light burned
Remove the screws from around the rear of the oven and slide the cabnet off to the rear. You should be able to access the bulb from here.
WARNING: any time you work on a microwave you have to be careful of the capacitor. Unpluge the microwave and discharge the capacitor with a large screwdriver with a plastic handle.
Be careful.
Why is it when I
this is fixya not the service company need to notify them about your inquiry
6/4/2017 2:05:37 AM •
General...
Answered
on Jun 04, 2017
Coffee spilled microwave while heating now microwave is dead it is a general spacemaker what can I do
Wow, generally a spill in a microwave shouldn't be catastrophic, but if it blew the wall plug, something bad happened. What do you mean it blew the plug? Did it simply trip a GFI? a breaker? Either way something must be amiss inside. Best case is a blown fuse in the microwave. You can look inside for evidence of a short but follow all safety practices and ensure the unit is depowered and steer clear of the big capacitor as it could still be charged.
12/28/2014 7:51:03 PM •
General...
Answered
on Dec 28, 2014
Hello my Teka MCX 45.1 BIT microwaves start button not appearing?
Microwaves generally last about 2000 hours before losing power. Here are some basics to try: Make sure the power plug is securely plugged into the wall outlet. Listen for an audible click when you close the door. Unplug it, wait 30 seconds, plug it back in (this may reset it). If the start button is then not appearing, there may be a problem with the touchhpad or control panel. Teka's customer service:
https://www.teka.com/global/support/
