20 Most Recent GE Spacemaker JVM1750 Microwave Oven Questions & Answers
2answers
Everything works on the micro wave except it will
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
12/24/2017 9:45:45 PM • GE Spacemaker... • Answered on Dec 24, 2017
The microwave turns on when we open the door. Is there a switch that can be replaced to fix this problem
Yes . The door switch is either out of adjustment or faulty.
4/27/2016 11:08:02 PM • GE Spacemaker... • Answered on Apr 27, 2016
The turntable doesn't turn.Will using the microwave until I can replace the motor harm anything?
If the turntable platform has wheels sometimes they accumulated grease or other material that gums them up. This will cause the turntable to lurch and/or jump during rotation. Remove the platform and soak it in hot soapy water taking care to clean each wheel. Rinse, dry and re-install the platform.
2/5/2015 1:57:34 PM • GE Spacemaker... • Answered on Feb 05, 2015
Replace inside light bulb
gonna needa open it up theres about 6 screws holding the covere and it like a small light blub u can uncrew it or if not it has a has a clip u pull off and are able to change it
10/13/2014 6:27:22 PM • GE Spacemaker... • Answered on Oct 13, 2014
0answers
0answers
0answers
No power. replaced the fuse turned on making noise power off
you have a shorted diode replace Cheers
12/10/2013 3:19:06 AM • GE Spacemaker... • Answered on Dec 10, 2013
Reading F3 and workes by it self
MAKE THIS TEST AND FIX IT. God bless you
  1. Interlock switchIf your microwave is turning itself on, the first thing to check is the interlock switch. This is usually the first thing to malfunction that could cause this issue. If the interlock switch is bad then it will need to be replaced.
  2. Main control boardIf your microwave is turning itself on and the interlock switch is still working, the probable cause is the main control board. If the control board is defective it will need to be replaced.
11/14/2013 12:50:42 PM • GE Spacemaker... • Answered on Nov 14, 2013
GE MICROWAVE TRAY (PLATE) WILL NOT TURN
1) small motor defective repair or replace2)plastic drive coupling+ring and rollers you must shure is working properly, fix it.God bless you7_17_2012_1_47_12_pm.gif7_17_2012_1_47_42_pm.gif
7/17/2012 1:47:58 PM • GE Spacemaker... • Answered on Jul 17, 2012
No power
Hello there and welcome to fixya This a fairly common issue with these microwaves Normally what the problems turns out being that the fuse that sits on the controle board inside So what you are going to have to do is first remove the outer shell this is done by removing the screws that are on the edge of the unit along the back then remove the screws on the sides then all you have to do is to slide the cover back towards the rear abnout 1/4 inch then the cover should lift off ok?the fuse sites on the right side on a electronic board on the right side as you look at he microwave from the front simply remove the fuse and replace it WITH THE EXACT SAME FUSE THIS IS VERY IMPORTANT then test the microwave it it now works great all u have to do is to put the cover back on and you are done okHowever if it does not work then you will have to investigate the power inverter and have it tested this part can be expensive (just to let you know ) ok?Please keep me informed on how this is going post me a comment ok?Best regards Mike
2/14/2012 1:53:46 AM • GE Spacemaker... • Answered on Feb 14, 2012
I have a new JVM1750 just installed yesterday.
That is your stirrer cover.Any arcing there is usually due to grease or food particles, so on a new oven that would be as mystery.But any time you get arcing under it, it has to be removed and cleaned.
10/18/2011 5:26:39 AM • GE Spacemaker... • Answered on Oct 18, 2011
I have a new
Inside there's a little door switch there's 3 of them they have to be in sequence You can adjust them with a screwdriver phillips
9/22/2011 12:21:47 AM • GE Spacemaker... • Answered on Sep 22, 2011
I have the GE JVM2070BH02
Check the door switches with ohm meter and make sure they are working properly, the door switch has been known to disable the keypad when faulty.
3/13/2011 5:53:17 AM • GE Spacemaker... • Answered on Mar 13, 2011
GE Spacemaker JVM1750 Microwave Oven Logo
45 questions posted
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
GE Microwave Ovens
  • GE Microwave Ovens
Most Popular Question
microwave turns when open door switch
  • Microwave Ovens
