20 Most Recent Maytag MDB7751AWS Built-in Dishwasher Questions & Answers
Hello, rob
I was trying to help you out here. I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://beta.fixya.com/users/mc1bean
Maytag... | Answered on Oct 27, 2011
Hi
The issue seems to be with the float switch assembly (part#27) that is bad and should be replaced. Please check this diagram....part#27,30, 31 is what you have to check. Your float assembly is found inside the dishwasher's tub, on the bottom. The water that fills your dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with your dishwasher's filling and/or draining ability. Use your voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If your switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
Maytag... | Answered on Feb 05, 2011
Perhaps a safety switch somewhere. I would check inside for a utensil that fell down into the impeller or the like. Also look at the door latch area; maybe a switch there is not closing properly.
Maytag... | Answered on Oct 25, 2020
To reset those you need to interrupt the power to the unit, you can do this by finding the breaker it is on and turning it off for a minute or two. Then try again and let us know
Maytag... | Answered on Jul 22, 2020
I am not familiar with the model but I doubt it - few people these days use the highly inefficient soap dispenser, preferring to add detergent directly into the wash drum.
I suggest you read the instruction booklet.
Maytag... | Answered on Mar 08, 2020
Sorry I only have more questions. If you observe the following things it may help rule out the thermostat or heating element . There are similarities to my problem. My dishwasher run for 4 seconds and stops briefly and starts again and will do that for ever.
1. Will it run properly in RINSE ONLY mode?
2. Does it run constantly or stop /starts continuously?
3. Does the soap dispenser open?
4. Does the timer count down? Ie cycle reads 2H and counts down, at least on my model.
5. Finally noticing if all the normal sequencing is happening. Ie turns on, pump empties the dishwasher, fill occurs, arms spin, and so forth. you should be able hear the unit empty and refill again and the rinse light goes on.
Sorry I could'nt be more help but possibly we can help each other.
Maytag... | Answered on Mar 07, 2020
i don't know. sounds like a fault in the program. consider unplugging machine for 10 mintes. plug it back in and run a short wash to see if the program has reset itself. if not OK, call for repair estimate then decide if you can live with it as is,-- have someone try to repairit -- or replace it with a new one which may offer extended warranty for $$.
Maytag... | Answered on Nov 03, 2019
Yeah, those Maytag DW's are known for having latch problems. Usually, you can just pull the door open by pulling hard. But if that doesn't work, you might be able to unscrew the latch, and then open the door. With the door open, you can now take it apart to get to the latch and replace it.
Maytag... | Answered on Oct 03, 2019
I would try turning off all power to it for few minutes and see if it reset it’s self, before I go to any great expense.
Also I had a washer that quit working on one cycle but would work on the others, could try that as well. Hope this helps!
Maytag... | Answered on Jun 30, 2019
First step is similar to a computer. Reboot. Turn off your dishwasher at the breaker box. Hopefully your electrician designated a separate breaker for your dishwasher, otherwise whatever else is on that breaker will be off. Shut the breaker off; wait 10-15 minutes; turn breaker back on. This will resolve many issues and is the first step to try.
Maytag... | Answered on Jun 08, 2019
Shut the dishwasher off at the breaker. then restart it. See if that clears the board.you may have put the machine into a control lock out. Look for that button. press and hold it for 3 seconds. see if that doesn't clear the board.
Maytag... | Answered on May 25, 2019
Maytag MDB7751AWS Built-in Dishwasher Logo
Popular Tags
8 questions posted
Top Maytag Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Marvin
Marvin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Maytag Dishwashers
  • Maytag Dishwashers
Most Popular Question
model mdb4651aws built in
  • Dishwashers
