20 Most Recent Whirlpool DU930PWS Built-in Dishwasher Questions & Answers
Possible blockage in the waste pipe.
Whirlpool... | Answered on Jul 14, 2014
check that the float is not stuck.. it should be down when not in use and should move up and down smoothly.
Whirlpool... | Answered on Mar 21, 2014
You can try a magnet, or remove the filter to get the screw
Whirlpool... | Answered on Mar 12, 2013
It is possible that themachine does not start off the cycle because there are errors or feedback fromthe inputs. For the program to start up the main program controller mustinitiate the INLET/PUMP MOTOR/DRAIN to workwhen it is commanded .If this does not happen then the voltage at thesepoints must be checked or the faultrelates to no voltage/drive from the controller. This means the controller is asuspect.Checkhow to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html
Whirlpool... | Answered on Jul 06, 2012
http://shared.whirlpoolcorp.com/product_literature/search.jsp
Whirlpool... | Answered on Dec 16, 2011
Your main control board would have failed and will need to be replaced.
Whirlpool... | Answered on Mar 10, 2011
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble
No Water entering Dishwasher
heatman101
Whirlpool... | Answered on Jan 06, 2011
remove the toe kick panel below the door there are 2 or 4 screws holding this panel,then to remove the pump you will need to tilt the machine upward to get enough room to remove pump whi9ch will require the water and electrical supply connections be removed
Whirlpool... | Answered on Jan 01, 2011
Sounds like a power supply issue. Take off the lower panels below the door and look to the right side of the opening, you will see a little square steel cover. This cover is where your power comes into the dishwasher. Follow the line coming into the dishwasher, it will either be a power cord that leads to an outlet, or a regular power line coming in. IF it leads to an outlet, try plugging something into the outlet. If the outlet is under the sink, try switching the plug from the top outlet to the bottom one (or vice~versa). Sometimes the outlets under sinks are set up so that a garbage disposer can be plugged into one of the outlets that is controlled by a wall switch.
If you get no power to the outlet, and all of your breakers are on, look for a GFI outlet that may have been tripped. These outlets have the little "test" and "reset" buttons on them and often are wired in parallel so that multiple outlets are powered (and protected) by one GFI.
Lastly if you have determined that there is power to the outlet, remove the cover under the dishwasher and inspect the wire connections. I have found many machines that had poor connections causing the wire nuts to burn right off the cord connections.
Now if everything else checks out power wise, you may have a blown fuse located on the control board housing inside the console of the machine. Get the part before you disassemble the door. To access it you will have to remove all the screws around the inner door liner and separate the two halves of the door. The control board is in the top right corner of the door and is usually under a plastic cover. The fuse is a small white thing that clips to the control board housing.
Good luck! Hope this helps you out!
Whirlpool... | Answered on Jun 27, 2010
Your touch pad control panel has gone bad. The part alone is about $150. not counting a house call and labor. If this machine is over three years old I recommend replacing it. A repair without a warranty is not cost effective. Joe
Whirlpool... | Answered on Apr 05, 2010
This just happened to me recently on my Whirlpool. My dishwasher indicates that the "Air Dry" button will lock it out if held in for 5 seconds. To unlock it, hold this button in for another 5 seconds or until the lock out light goes out. Hope this helps.
Whirlpool... | Answered on Apr 02, 2010
the drain pump is working because its hums.
so that leave water going into unit which can be checked with turning the water off and disconnecting to see if water is coming out and water valve problem which can be checked with a meter for continuity.
but a very rare case where the pump is stuck in drain mode because it thinks it has water in the base from a leak in the hose. so check these things and im sure the problem will reveil itself. let me know with a 4 thumbs up post
Whirlpool... | Answered on Feb 27, 2010
Whirlpool DU930PWS Built-in Dishwasher Logo
38 questions posted
Top Whirlpool Dishwashers Experts
Mike
Marvin
Marvin
Ekse
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Dishwashers
Most Popular Question
will not start light flashing
  • Dishwashers
