20 Most Recent Siemens SL85A705UC 24 in. Built-in Dishwasher Questions & Answers
Check latch assembly for proper operation. There is a switch there that if not properly activated will kill power to machine.
If part needed check at site Search Over 2 1 Million Appliance Parts
Siemens... | Answered on Aug 31, 2017
Hello & Welcome to FixYa
When the water comes however, won't go inside the unit then it indicates that the problem is either with a clogged/blocked inlet valve or the water inlet valve itself has gone bad and needs replacement. You can also test two terminals of the water inlet valve before replacing it. Please get back to me if you have any other questions.
Kevin
Siemens... | Answered on Dec 09, 2011
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Siemens... | Answered on Jul 21, 2011
the control computer is bad. the relay on the control for the pump is stuck. if its less then 5 years old it should be under warrnty. look for your owner book. find the warrnty section. it should have a service number to call.
Siemens... | Answered on Feb 04, 2011
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Siemens... | Answered on Aug 13, 2010
There is a pan above the base. That is where the sensor is right below the pump and hoses. You need to remove the rear or side panel. If the machine states you have a leak, you have.
Bosch, Neff, Siemens washing machine clearing error code ...
https://www.youtube.com > watch ? 5:12
Jan 8, 2018 - Uploaded by how-2-repair.com
Tutorial: https://www.how-to-repair.com/help/bosch-neff-siemens-washing-machine-clearing-error-code ...
Siemens... | Answered on Mar 02, 2020
Siemens SL85A705UC 24 in. Built-in Dishwasher Logo
Popular Tags
17 questions posted
Top Siemens Dishwashers Experts
Paul Bade
Mike
aliasger yq
Are you a Siemens Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Siemens Dishwashers
  • Siemens Dishwashers
Most Popular Question
siemens dishwasher working
  • Dishwashers
