20 Most Recent LG LDS4821 24 in. Built-in Dishwasher Questions & Answers
2answers
LG Dishwasher Leaks
Hi Jim,I recently noticed exactly the same symptoms with my LDS4821 which I think is a similar age.After a bit of head scratching and a similar door cover removal exercise I also figured it must be coming via that round vent and then on down the plastic duct that runs to the bottom left vent in the door that you photographed.Here's what I did which has certainly fixed my leak:1/ First I cleaned around the inside of the round vent on this inside of the door. Specifically I removed all the accumulated crud around the edges of the circular yellow rubber gasket piece at the center of the vent on the inside the machine (your first photo). I did this after untwisting the circular grill that holds that in place - my vent unit behind that grill also wiggles around by the way, but only when that round grill has been unscrewed! I was careful to make sure that the unit behind the grill was seated properly again when I twisted the grill back on to tighten it and hold it in place again. I actually checked this with the front of the door taken off for this second step below to make sure there would be no issues with the outer seal around that vent unit (where it presses up against the inside of the metal door to form a seal when the round vent grill is srewed on).2/ This I think is actually the critical step. I noticed a second black hose that runs down from the plastic vent structure almost directly behind where the round grill is positioned on the inside of the door. See the picture I've attached re. the tube I am talking about. Looking at this I figured it's some kind of internal drain (that seems to drain back into the washing compartment itself at the bottom). Given that I'd seen some crud on the yellow rubber gasket I wondered if some crud had also blocked the top of this hose, leaving any water that gets in there to then run on down and out of that vent at the bottom instead. Sure enough when I employed the crude (but apparently effective!) technique of sucking on the bottom end of that tube to see if it was clear, I soon enough felt a blockage break and I just had time to aim the tube away before a bunch of grey crud came sweeping down the tube, followed by some clearer water. By the looks of it you might be able to unclip the hose clamp at the top and do it somewhat more professionally to avoid the risk of a mouthful of 2-3 year old dish crud in your mouth!I've just run it through a full 'normal' cycle and it's back to working normally again - no more leaks.Well dishwashers may **** at times, but apparently I do too...Hope this helps.-Dan8_1_2012_6_30_06_pm.jpg
1/10/2015 7:50:35 PM • LG LDS4821 24... • Answered on Jan 10, 2015
Touch pad on LDS4821 is not working
replace the touch pad and it should work
6/9/2014 3:29:34 AM • LG LDS4821 24... • Answered on Jun 09, 2014
I have a 2 1/2 year old LG diswasher modelLDS4821WWW , when I turn the power all lights are on ,then the Wash light flashes and not taking any water
check and make sure the water is turned on under sink if it is the water valve is bad on the dishwasher
7/29/2012 4:00:18 AM • LG LDS4821 24... • Answered on Jul 29, 2012
0answers
2answers
Chalky milkey white residue on dishes / dishes not
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
11/15/2011 11:41:19 PM • LG LDS4821 24... • Answered on Nov 15, 2011
I have a LD-1415T1 lg dishwasher it does not have
Hello, moody I was trying to help you out here. I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>> http://home.howstuffworks.com/dishwasher.htm Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike http://beta.fixya.com/users/mc1bean
10/27/2011 9:19:04 PM • LG LDS4821 24... • Answered on Oct 27, 2011
LG LDS4821 Appears to be leaking from the drying
The leak is coming from the loose gasket in the fan assembly (blower) connected to the vent cover. What I did to fix my leak was a simple step of adding petroleum jelly (e.g., Vaseline) around the gasket holder and reuse the same gasket (clean all parts first, including the gunk inside the fan blower assembly) and the leak stopped!! My wife was so proud of me!
10/23/2011 12:47:01 AM • LG LDS4821 24... • Answered on Oct 23, 2011
Oe code. Will not
Hi
OE in your dishwasher is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. If the issue returns after cleaning then the drain pump assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
8/30/2011 3:29:22 PM • LG LDS4821 24... • Answered on Aug 30, 2011
Keeps stopping and showing OE
Hi tpearsgolf,
The "OE" error code you are seeing, means "Outlet Error"
The drain pump is either clogged, or the outlet hose has been kinked.
- Inspect the Drainage hose at the back for kinks. - If any, straighten the hose
- Open the unit, and at the bottom sump check the small drain pump area for any foreign object that may be obstructing it. You can remove the filter, as well as the metalish sieve underneath it, check the sump underneath near the drainage holes, make sure nothing is obstructing the flow out of the machine from there.
If not successful, you will need to replace the Drain Pump.
Kind Regards :-)
If you found this solution helpful, please rate it.
7/6/2011 5:06:34 PM • LG LDS4821 24... • Answered on Jul 06, 2011
Water is not draining.... OE symbol appears on
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter by removing the bottom front access panel for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
6/12/2011 12:06:13 AM • LG LDS4821 24... • Answered on Jun 12, 2011
Our LG dishwasher is not dispensing detergent like
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem
Detergent Cup does not Open
heatman101
4/25/2011 10:28:56 PM • LG LDS4821 24... • Answered on Apr 25, 2011
Dishwasher is not emptying the water at the bottom
did u check the drain to see if its clogged
4/9/2011 7:45:59 PM • LG LDS4821 24... • Answered on Apr 09, 2011
Why is the water still
Drain pump not working anymore. Check the outlet hose and let it lie on the floor to drain most water out of the dishwasher, then remove the Top Panel (fastened by 2 screws at the back) and then the side panels. A normal Dishwasher should be attached to the sump.
Kind Regards :-)
* If you found this solution helpful, please rate 4 thumbs up and leave a small testimonial. :-)
4/9/2011 1:00:28 PM • LG LDS4821 24... • Answered on Apr 09, 2011
My LG dishwasher is leaking from the bottom
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
3/20/2011 7:59:43 PM • LG LDS4821 24... • Answered on Mar 20, 2011
My lg dishwasher is leaving food particles on
Check for blockage of the spray arm holes. If they are clear, replace the VIRO motor. It is a small motor next to the main wash motor, which turns a cam, directing water to the bottom, then the top spray arms. (usually, changes position every 2 minutes or so) You will need to remove the dishwasher from the cabinet to replace the VIRO motor.
3/6/2011 5:45:05 PM • LG LDS4821 24... • Answered on Mar 06, 2011
How do i mount the
THERE ARE A FEW STEPS TO THIS.
1) MAKE SURE YOU HAVE A SEPERATE FUSE AND ELECTRICAL WIRE LEADING TO YOUR DISHWASHER AREA. ITS REQUIRED BY ELECTRICAL CODE.
2) WILL NEED A WATER LINE RAN OVER TO THE DISHWASHER AREA.
3) YOU WILL NEED A WATER DRAIN LINE RAN OVER TO THE DISHWASHER AREA.
ONCE THESE ARE THERE, THEN ALL THE CONNECTIONS CAN BE MADE.
MOUNTING THE APPLIANCE REQUIRES A CERTAIN SIZE SPACE UNDER THE KITCHEN COUNTER. YOUR INSTALLATION INSTRUCTION BOOK WILL TELL YOU THE SIZE REQUIRED
IF THERE WAS NOT ONE THERE BEFORE.
2/21/2011 1:48:55 AM • LG LDS4821 24... • Answered on Feb 21, 2011
LG LDS4821 24 in. Built-in Dishwasher Logo
42 questions posted
Top LG Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
LG Dishwashers
  • LG Dishwashers
Most Popular Question
our lg dishwasher not dispensing
  • Dishwashers
