20 Most Recent Electrolux EIDW6105GW 24 in. Built-in Dishwasher Questions & Answers
Hello friend, thank you for your post!
It is possible that one of your gaskets need to be replaced inside of your dishwasher. I would recommend having a technician come out and properly diagnose your appliance. Hope this helps. -Matt
Electrolux... | Answered on Sep 05, 2014
Hi
The issue is either with the wash pump that is going bad or the motor itself that is unable to run. As the washer fills and then drains immediately so the pressure/float switch should also be checked. Hope this helps...please post back for further assistance.
Daniel
Electrolux... | Answered on Jan 23, 2011
Hi
Error code F12 means a shorted connection or wiring on keypad. Turn off & unplug the dishwasher for 2-3 minutes and check the error doesn't appear. If this doesn't resolve the issue then you'll need to disassemble the keypad and check the connections on the keypad, also make sure that the wiring is also fine. If the connections and wiring seems to be fine then use a multimeter to check the continuity between the connections on the keypad. Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Electrolux... | Answered on Sep 30, 2010
very important! the machine must be perfectly level or slightly tilted higher in the front . If not the leak detector function will engage and the machine will not operate. Try raising the adjustable feet behind the kick plate.The machie may reset without removing it.
Electrolux... | Answered on Aug 26, 2010
Have you got any indication of error codes in the display if not check the child safety lock is not set or the disable of display is not set.I guess you have a manual it gives all the error codes in this.
Hope this helps.
Electrolux... | Answered on May 30, 2010
http://www.partselect.com/dishwasher+repair+repair.htm
http://frigidaireservicetips.com/pdfs/486_5.pdf
Top link a DIY help site shows you how to troubleshoot. below that, is a service and repair manual, this is what the engineers use to troubleshoot and repair.
Electrolux... | Answered on May 11, 2010
Lights flashing, will not operate
Electrolux... | Answered on Feb 13, 2010
Call the manfacturer and tell them your problem give them make, model, and date of purchase They should be happy to help you.Esp.since it is still under warranty
Electrolux... | Answered on Jan 09, 2010
Hello, I've got a suggestion and at first it may sound like I'm pulling it out of my...left field. I'll tell you the what and then I'll explain why. Try this, take a rag or paper towel and soak it with "rinse aid" AKA, "jet dry" and apply it to the top of the tub and to a lesser degree the sides as well. I suggest this to all my customer's with new dishwasher's. Now the why...all dishwasher's require assistance to dry your dishes, some more than other's. Hence the need for an additive such as jet dry, it is simply a wetting agent which help's the water run off the dishes and as a result they dry better. So why put it on the tub ? Glad you asked. The reason is exactly the same, on older dishwasher's that have had many year's of use the tub has already built up some wetting agent on the tub just by normal and continued use, the new obviously has not. The only jet dry the new one has is the added amount in the dispenser. Over a short time of regular use the unit would start to dry better on it's own, this just speed's up the process. By adding the jet dry to the tub you create a seathing action allowing water to run off before & during the dry cycle as to not have water in the form of condensation dripping back onto the dishes when the cycle is complete, which leaves you with dry dishes as opposed to wet dishes. Make sense ? I hope so, it really work's. Hope you found this helpful. If so please rate the info you received frome jere at "fixya" today and good luck. Let me know if I can assist you further. I hope you didn't find this too difficult to read, I had to use my iphone, it's the only internet connection I have at the moment. Macmarkus :)
Electrolux... | Answered on Jan 07, 2010
error code e4
Electrolux... | Answered on Oct 14, 2009
Electrolux EIDW6105GW 24 in. Built-in Dishwasher Logo
37 questions posted
Top Electrolux Dishwashers Experts
Mike
Marvin
Marvin
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Electrolux Dishwashers
Most Popular Question
dishwasher starts fill
  • Dishwashers
