20 Most Recent Maytag MDB8751BWQ 24 in. Built-in Dishwasher Questions & Answers
Here is a tip that I wrote that will help you with your problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Maytag... | Answered on May 15, 2010
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Maytag... | Answered on Mar 22, 2010
Remove the outer case, the drain hose is at the bottom rear.
Maytag... | Answered on May 07, 2020
I am not familiar with the model but I doubt it - few people these days use the highly inefficient soap dispenser, preferring to add detergent directly into the wash drum.
I suggest you read the instruction booklet.
Maytag... | Answered on Mar 08, 2020
Sorry I only have more questions. If you observe the following things it may help rule out the thermostat or heating element . There are similarities to my problem. My dishwasher run for 4 seconds and stops briefly and starts again and will do that for ever.
1. Will it run properly in RINSE ONLY mode?
2. Does it run constantly or stop /starts continuously?
3. Does the soap dispenser open?
4. Does the timer count down? Ie cycle reads 2H and counts down, at least on my model.
5. Finally noticing if all the normal sequencing is happening. Ie turns on, pump empties the dishwasher, fill occurs, arms spin, and so forth. you should be able hear the unit empty and refill again and the rinse light goes on.
Sorry I could'nt be more help but possibly we can help each other.
Maytag... | Answered on Mar 07, 2020
ask google to see if they find it
Maytag... | Answered on Nov 11, 2019
i don't know. sounds like a fault in the program. consider unplugging machine for 10 mintes. plug it back in and run a short wash to see if the program has reset itself. if not OK, call for repair estimate then decide if you can live with it as is,-- have someone try to repairit -- or replace it with a new one which may offer extended warranty for $$.
Maytag... | Answered on Nov 03, 2019
Yeah, those Maytag DW's are known for having latch problems. Usually, you can just pull the door open by pulling hard. But if that doesn't work, you might be able to unscrew the latch, and then open the door. With the door open, you can now take it apart to get to the latch and replace it.
Maytag... | Answered on Oct 03, 2019
Could be door switch failure. That's a cheaper alternative to replacing the control board.
Maytag... | Answered on Sep 15, 2019
The control board seems a good candidate for replacement, especially in view of the jumping around.
Maytag... | Answered on Jun 30, 2019
First step is similar to a computer. Reboot. Turn off your dishwasher at the breaker box. Hopefully your electrician designated a separate breaker for your dishwasher, otherwise whatever else is on that breaker will be off. Shut the breaker off; wait 10-15 minutes; turn breaker back on. This will resolve many issues and is the first step to try.
Maytag... | Answered on Jun 08, 2019
Shut the dishwasher off at the breaker. then restart it. See if that clears the board.you may have put the machine into a control lock out. Look for that button. press and hold it for 3 seconds. see if that doesn't clear the board.
Maytag... | Answered on May 25, 2019
Maytag MDB8751BWQ 24 in. Built-in Dishwasher Logo
4 questions posted
Top Maytag Dishwashers Experts
Mike
Marvin
Marvin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Maytag Dishwashers
  • Maytag Dishwashers
Most Popular Question
dishwasher wont drain maytag quiet serie
  • Dishwashers
