20 Most Recent LG LDS4821WW 24 in. Built-in Dishwasher Questions & Answers
2answers
Dishwasher works great, but makes a high pitched
This is usually a dry seal, will eventually leak, suggest exploritory surgery....
1/20/2015 6:15:22 PM • LG LDS4821WW 24... • Answered on Jan 20, 2015
Drain cycle starts prematurely
Check the drain pipe for the required height it may be lower than recommended height to make it anti syphon.
1/19/2014 12:44:01 AM • LG LDS4821WW 24... • Answered on Jan 19, 2014
Hi I have a LG
Hello, degraa I was trying to help you out here. I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>> http://home.howstuffworks.com/dishwasher.htm Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike http://beta.fixya.com/users/mc1bean
10/27/2011 9:23:23 PM • LG LDS4821WW 24... • Answered on Oct 27, 2011
I have an LG Lavavajillas dishwasher and the hose
I have not seen this model here in Australia, so I am not sure if the box you are referring to is the inlet solenoid or a pressure limiter. It would be a difficult task to disconnect the hose from the other end where it attaches to the base internals of the machine.
Two suggestions:
1) Drill a big hold in your cabinet to allow the hose fitting to pass through.
2) Or you can get a hose adapter and attach a second hose on the end of this one. The normal inlet hoses would have a small head so you can pass this through the existing hole in your cabinet. If you do this make sure the excess hose is tucked away under the cabinet, when you push the dishwasher in, otherwise you will get kinks in the hose.
Ash
9/17/2011 5:13:13 AM • LG LDS4821WW 24... • Answered on Sep 17, 2011
From the start, the dishwasher is showing an erroe
Hi amloots,
The E1 error can be fixed by following my Tip below:
L.G DISHWASHER E1 ERROR...
Follow these directions, and the problem will be fixed.
Kind Regards :-)
* If this solution helped you, please rate it.
7/30/2011 11:26:03 PM • LG LDS4821WW 24... • Answered on Jul 30, 2011
Our dish washer stop and the e1 light come on,
The E1 you are seeing means the following: Water Level in Drum lowering, this means there is a leak on one of the pipes.
But from previous experiences it is more than likely that it is the Circulation pump. It will have to be replaced, as it is a common spare that has to be replaced on L.G Dishwashers (lifetime expectancy: 12 - 18 Months) - Not very expensive.
Usually is about 20%-25% the price of a new Dishwasher. The Circulation pump is fitted to the sump. Part Number: 5859DD9001A or 5859ED1001A (Depending which one is in stock)
Good Luck :-) - J.Q
* If you found this solution helpful, please vote positively. A 4 four thumbs up will do nicely too :-)
4/11/2011 3:28:38 AM • LG LDS4821WW 24... • Answered on Apr 11, 2011
Dishwasher will not drain water
The filter is probably blocked.
It is inside the base of the machine.
Take out the filter and clean it and also clean out the filter well as that can also hold quite a bit of debris.
Please dont forget to vote this answer was helpful
Many thanks
2/13/2011 5:58:03 PM • LG LDS4821WW 24... • Answered on Feb 13, 2011
The panel has a LE ERROR.
LE is an ie .. water inlet problem. ... manual says to check for clogged, kinked, or frozen water inlet hose. check water supply.
OE. Drainage problem
FE excessive water supplied
E1 water leakage problem
HE heater circuit failure
TE thermistor failure, or very high inlet water temp
PF. power failure.
2/5/2011 11:55:31 PM • LG LDS4821WW 24... • Answered on Feb 05, 2011
Ripped off a trim piece...help!
check with LG I am guessing on line... .
2/5/2011 11:53:25 PM • LG LDS4821WW 24... • Answered on Feb 05, 2011
Dishwasher compartment
pour right into the main opening( under the cap where you see the lever with 1,2,3.. the 2 slots are simply air holes... liquid will drain through..some bubles are normal.
2/5/2011 11:50:47 PM • LG LDS4821WW 24... • Answered on Feb 05, 2011
How to secure dish washer to cabinet
p8 of the install manual speaks to brackets/screws/ caps used. Screws/caps are on the inside of the tub on the frame
2/5/2011 11:49:14 PM • LG LDS4821WW 24... • Answered on Feb 05, 2011
Bottom drawer does not have a hard stop. Drawer
check the level of the Dw per the instructions.. may need to raise the front up... If you take the front kick plate off( 2 screws) there are 2 white feet at the front... also phillips screws above(inset) that control the height of the back 2 feet.
Manual tells you where to place the level.. for plumb levelling the manuals stated to put the level on the front side of the cabinet( where the door closes on to)... on the vertical side. Adjust the front feet down, or the back ones upward( need to watch to keep the side to side level when doing this too...
Good luck
2/5/2011 11:47:03 PM • LG LDS4821WW 24... • Answered on Feb 05, 2011
Lights are flashing with OE
OE is a drainage problem. Check all lines, and drains for kinks.blockage. Ours was blocked in the T connection where the drain goes into the sink( in the black ABS sink part.) Used a screwdriver to simply clear the t connection with the drain hose disconnected.... ran the DW( where it fills w/ water) ,then turn off, and put the drain hose into a bucket... if its pumping water out well, then it could be the sink drain.
If not... a line somewhere is plugged.
2/5/2011 11:42:38 PM • LG LDS4821WW 24... • Answered on Feb 05, 2011
We need to purchase the left handed screw that
recommend right from LG.
in canada ca.lge.com, or 1-888-542-2623
2/5/2011 11:39:32 PM • LG LDS4821WW 24... • Answered on Feb 05, 2011
LG LDS4821WW 24 in. Built-in Dishwasher Logo
50 questions posted
Top LG Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
LG Dishwashers
  • LG Dishwashers
Most Popular Question
our dish washer stop e1 light come
  • Dishwashers
