20 Most Recent
KitchenAid KUDD03STSS Stainless Steel 23 in. Built-in Dishwasher Questions & Answers
How to unlock the dishwasher
IT SHOULD PULL STRAIGHT OUT. IF VERY HARD OR WONT PULL OUT WITH SLIGHT FORCE, THE DOOR LATCH HAS BROKEN AND THE LATCH AND STRIKE NEED REPLACING. I PERSONALLY RECOMMEND REPLACING THEM BOTH ANYWAY INCASE IT DECIDES TO MALFUNCTION IN THE FUTURE HOPE THIS HELPS AND THANK YOU FOR READING..
Kitchenaid kudd03stss dishwasher locked indicator
Hi
First try to reset the dishwasher control by pressing
the HEATED DRY button and hold it for 15 seconds, if its still not resolved
then it means that the control board has gone bad and should be replaced. Hope
this helps...please post back for further assistance.
Daniel
Dishwasher wont drain
Sounds to me like your drain line is plugged .
Remove excess water from the dish washer, shop vac works great if you have one.
remove the drain line from the bottom of the pump.
Remove the hard line from the pump with a set of pliers, inside you will see a diaphragm, this is were rice or corn will get lodged causing a blockage. Remove debris, check o-rings to ensure they are in good condition, re0attach hard line and hose.
Hopefully this helps you out.
Kitchenaid KDPM604KPS dishwasher stops minutes into cycle
I couldn’t find any error code 2H but I did find an error code H2O. This code means insufficient water pressure. If the display reads 2H, it usually means the start delay function is turned on. The dishwasher will turn on in 2 hours if door is closed. This dishwasher is advanced. To understand all operations you should read the user guide or manual.
10/13/2022 10:19:23 AM •
KitchenAid...
Answered
on Oct 13, 2022
What is the correct button sequence etc to do a panel reset on a kitchenaid KUDE60HXSS1
Pick any 3 consecutive keys (except Start or Cancel, then press them in the sequence 1, 2, 3, 1, 2, 3, 1, 2, 3. The dishwasher will go through a self-test and short cycle, and reset itself.
My child stepped on the
I had this exact same story with my new Whirlpool dishwasher. My daughter fell on the open dishwasher door and afterwards it wouldn't latch closed. After researching online, I learned that 90% of the time it's bent door hinges. At $$130 each, $260 total, I didn't want to replace the hinges. So I removed the hinges, took them downstairs to my shop, put them in the vise and straightened them back with a hammer. Just took a few good, solid hits on each hinge and they were straight again. I installed them back onto the dishwasher and it worked like a charm! Door latches just fine.
Rinse aid dispenser leaks
The dispenser needle valve is not seating properly and correctly causing it to be rinsing and also the aid to be leaking out water.
