20 Most Recent
Victory Commercial Freezer VF-3 Questions & Answers
Freezer is not getting cold.
Replace compressor,and clean or replace condensor and capillary Tube.
Condensor and capillart tube clogged with wire insulation from compressor causing partial cooling
and high compressor Heat.
Thanks
Leo Ponder
7/21/2011 5:00:33 PM •
Victory...
Answered
on Jul 21, 2011
My food deep freeze seems to run almost all the time whats wrong
If the machine is running all the time a few things could be happening, The defrost timer could be bad, but if that is the case then you should see a build up of ice forming on the wall that covers the evaporator coils. Another situation is that your machine is low on freon and not reaching a temperature cold enough for the temperature control to shut the machine off. Third and last the temperature control itself could be bad and thinks the machine isn't cold enough. in that situation you would notice ice build up as well. Hopefully this helps. If you need further help, I’m available over the phone at
https://www.6ya.com/expert/jason_4570d45317834dd3
My freezer will not hold temperature. Only a year
If what you say is accurate, I would look at either a weak compressor or and issue with the expansion device. (Cap tube, TXV)
What are your pressures and what freon are you using? Does the door(s) seal tight?
Replacement interior bulb socket
First off its the repair mans problem not an electrican, he probably knows its a hard job and does not want to do it, probably be alot of work to replace it, check with Victory an see it a replacement part is available an ask how hard to replace.
Tappan TFC13M0AW1 Chest Freezer. What part should I replace?
Question edited to add maker! All questions need 'make model (what it is) as first three words.
That is an overheating fault. Replace the fluff with no fluff.
Make sure the condenser coils are free of dust and there is good airflow
Or
It is low on refrigerant gas and you need a service tech..
2/3/2024 5:25:13 AM •
Freezers
Answered
on Feb 03, 2024
