20 Most Recent McCall Refrigeration Commercial Freezer 11045UF01 Stainless Steel Questions & Answers
you need model number and serial number . refrigerant type and possibly the compressor model number to determine the txv type and capacity
McCall... | Answered on Apr 18, 2013
If the condenser coil is clean and the unit is in an area where the ambient temp. is 80 degrees or less, it is most likely a refrigerant problem. Probably low and has a leak. Another issue could be that the line sizes for the distance the refrigerant has to travel, may be wrong. Since I don't know the distance, you may need to have that checked into also. You should not have more than a 1-2 psi drop due to line size and distance traveled.
McCall... | Answered on Sep 13, 2010
Your light switch is white generally around frame... As for door heater it will be on as soon as you plug unit it. You can feel around door jam to see if heating... Should be warm not scalding hot. McCall was sold to manitowoc and some parts are no longer available. If you're able to do repair yourself try case parts.
McCall Freezers | Answered on Dec 10, 2014
There are video's on google that have trouble shooting for Igloo ice maker types and for the Igloo ice company and YouTube.
Freezers | Answered 3 days ago
Cool and keep cool.
Freezers | Answered on Aug 04, 2020
Question posted under freezers but appears to be Ameriwood Industries furniture.
If you can identify the model number, you can download a free manual from Ameriwood Industries, which has a contact phone number to call for another model if that is different model furniture.
Example with telephone number:
https://www.ameriwoodhome.com/eng/AmeriwoodFiles/ProductDocuments/AmeriwoodFiles/ProductDocuments/19452_B345531309KP00%20instruction%20manual.pdf
https://www.ameriwoodhome.com/eng/instructions
Freezers | Answered on Jul 01, 2020
I wonder what the fixya software asterisked out?. Can you write the word
v
e
r
i
c
a
l
l
y
Freezers | Answered on Jun 29, 2020
Hi I have the same problem,
did you get an answer to your question..?
Freezers | Answered on Jun 15, 2020
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
That alarm light means that the unit was too warm for a period of time. The door may not have closed properly. It is a warning to you that the food may have thawed out. It does not mean something is wrong. To reset it switch it off and on or unplug it for a minute.
Freezers | Answered on Jun 14, 2020
https://www.bestbuy.com/site/shop/freezer-with-lock
Freezers | Answered on Mar 27, 2020
https://industrial.panasonic.com/ww/products/motors-compressors/compressors/reciprocating-compressors-fs/d-series-reciprocating-fixed-speed-r134a-lbp/D110C21RAX5%2528RSIR%2529
Freezers | Answered on Mar 21, 2020
McCall Refrigeration Commercial Freezer 11045UF01 Stainless Steel Logo
Popular Tags
3 questions posted
Top McCall Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
John Tripp
John Tripp
Are you a McCall Freezer Expert? Answer questions, earn points and help others
View Most Popular
McCall Freezers
  • McCall Freezers
Most Popular Question
mccall freezer installed 8 yrs ago in
  • Freezers
