20 Most Recent GE 14.8 cu. ft. General Electric Chest Freezer FCM15PUWW Questions & Answers
Will stop on it's own when it get cold again, but most generally have a manual alarm shut off (on back, near hinge on older models).
GE 14.8 cu. ft.... | Answered on Dec 17, 2013
there having a wires which got damaged otherwise your cooling having problem.
GE 14.8 cu. ft.... | Answered on Mar 26, 2013
When you say "cleaned", did you defrost it? And. if so, could you have damaged the internal lining? Often the coil inside the wall of a chest freezer can fracture if hit or stabbed at during defrosting.
Other than that, is the compressor running (you would hear it)? it may have overheated. If not running, see if it feels hot (siezed) or cold (no power from thermostat). If cold, put it on fast freeze and see if it kicks into life (thermostat faulty) or not (compressor fault, time for a new freezer!)
Let me know how you get on!
GE 14.8 cu. ft.... | Answered on Jul 05, 2012
The first thing I would do is to check the compressor and the condenser fan. Remove the cover on the back of the fridge and check how hot is the compressor? Is the condenser fan turning well? Also check the condenser coil under the fridge, it is very possible it needs cleaning.
If the condenser fan is not working properly then it has to be replaced.
If the condenser fan motor is fine and the cleaning did not help then the sealed system is low on Freon and in such case you need a certified technician to fix a leak and to charge the system.
Good luck in solving the problem...
GE 14.8 cu. ft.... | Answered on May 07, 2011
the noise you are hearing is probably the starting relay on the compressor failing and causing the overload protector to cut the power off to the compressor. Try replacing the overload and starting relay.
GE 14.8 cu. ft.... | Answered on Mar 05, 2011
However this will take long so you use a straight screwdriver or something like a chisel to remove as much scale as possible before leave it in solutions.
The ice build up is related from the time keep the door open and the humidity that is in the air. So the time is variable. Sometimes if the door is not sealed closed the ice is build up very fast.
GE 14.8 cu. ft.... | Answered on Nov 01, 2010
Here is the dimensions for your freezer. The over all length is 48 Inches or 4 feet.
Overall Height 35 in Overall Depth 29 1/2 in Overall Width 48 in
Good luck and please rate 4 thumbs up for the free answer
GE 14.8 cu. ft.... | Answered on Aug 29, 2010
http://www.appliancepartspros.com/repair-help/general-electric-refrigerator-gsl25jftabs-repair/gsl25jftabs-frost-buildup.html
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
GE Freezers | Answered on Jan 02, 2018
The 6 or7 may be a setting number or a degree readout, which is a little on the warm side, should be around a -10 to-15.
Consult your users manual for details ,.Does not sound like an emergency, but keep monitoring it'
https://www.repairclinic.com/RepairHelp/Freezer-Repair-Help
This site may be of help.
GE Freezers | Answered on Dec 15, 2017
It sounds like this is a a non DIY issue. there is really not much you personally can do.
Contact an authorized servicer fir best results
Gaskets can cause this, along with internal fans getting bad or iced over. Other answers might indicate a leak of freon.
GE Freezers | Answered on Sep 29, 2017
the users manual does not cover this particular issue as to the temperature swing. I have seen some thermostats that are the "constant on" type that you are describing. No way of telling from the vague manual. As long as you are not storing ice cream for a long period of time, 0 degrees is usually fine for most home applications. Sorry I can not give you more info.
GE Freezers | Answered on Aug 11, 2017
GE 14.8 cu. ft. General Electric Chest Freezer FCM15PUWW Logo
11 questions posted
Top GE Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
John Tripp
John Tripp
Are you a GE Freezer Expert? Answer questions, earn points and help others
View Most Popular
GE Freezers
  • GE Freezers
Most Popular Question
only 6 months defrost
  • Freezers
