20 Most Recent Smith Wesson Chronograph Titanium Watch Questions & Answers
I found a really good scratch remover on E-bay. Its just a small tube. You just wipe a tiny bit on the watch and rub with a cloth. It makes it look brand new. Just search for screen repair or watch screen repair on E-bay.
Smith Wesson... | Answered on Dec 07, 2010
First, reset the clock to 0:00 hours. The instant the clicking stops, pop out the battery. The second hand stem should be at 0:00 hours. The front cover can only be removed from the bottom. Put both thumbs at the bottom of the font cover and push inward, but not too forcefully (Junghans stopped selling replacement covers shortly after dropping the product line and they are nearly impossible to find). The center should lift up enough to slide a thin credit/promotion/gift card under the center tab on the bottom. Then work the card up either slide to disengage the other four tabs. The five tabs are located at the bottom center, one each on both straight sides alligned with the top of the digital display, one at 7.5 minutes, and the last one at 52.5 minutes. That is easy part. Now comes the hard one You then need to glue the second hand back onto its stem. Superglue (cyanoacrylate based) works best. The second hand must be attached perfectly level or it could scrape the cover, the clock face, and the other hands as it rotates on a tilt. Practice a few times before applying the glue. You will notice that the socket on the second hand fits the stem very loosely. Once you are ready to glue, apply one drop of superglue on the second hand socket and mount it on the centermost stem and hold it perfectly still and in proper alignment and steady for a minute or so for the glue to set. Once the glue dries, put the battery in and let it run long enough to determine if the second hand is in correct alignment. Remove the battery again. Make certain the clock face is completely free of dust and dirt before reattachment of the cover. Insert the cover from the top down snapping the five tabs into place. It may be necessary to reverse the removal process. Then you can reinsert the battery. The process worked for me when mine was accidentally knocked onto the carpet and the second hand was detached from the force of the impact. In fact, I can no longer tell which one I performed the repair on.
Watches | Answered 9 hours ago
Here is the manual
https://www.solsuno.com/solsunoinstructionenglish.pdf
Watches | Answered on Sep 24, 2020
Question is ........................
Watches | Answered on Sep 22, 2020
A jeweler can open it up and tell you.
Watches | Answered on Sep 19, 2020
I need the manual for Invicta Reserve 6207
Watches | Answered on Sep 13, 2020
Videos
https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk01WmOGe2GZe6LMNl0U7ilp2pAdB4g%3A1599149176787&ei=eBRRX8_TL8XE1QH866roAQ&q=Fast+track+model+no%3A+NK38033SP02+set+date
Watches | Answered on Sep 03, 2020
i see nothing here
Watches | Answered on Aug 26, 2020
The battery type may be indicated on the back. In any event, a jeweler can tell you.
Watches | Answered on Aug 25, 2020
This suggests one of three alternatives are at play: 1) You don't have the manual to the watch and thus don't know the sequence to turn off the alarm n chime; 2) You have the manual and it is inaccurate. 3) The watch is defective.
https://www.amazon.com/ask/questions/Tx3VS2PTPQUSRAG/
Watches | Answered on Aug 24, 2020
Tip & How-To about Watches
Changing Watch Batteries
Lots of posters ask "what is the battery in my (name of watch)" with a view to changing it yourself. This is a bad idea for many reasons. You don't have the tools or knowledge to remove a rotary screw on back, or the gasket sealant for a waterproof watch. Some fashion watches have 4 traditional screw and need professional grade jeweler screwdrivers. Also, there are about 20 batteries commonly used in watches, in various sizes and internal technology, Lithium Ion, Silver Oxide and Manganese Alkaline. If you buy them, you generally have to buy 10!
Don't sweat the details. Just take the watch to your local jeweler. They have all the batteries at hand and the tools to remove the back. It is done whilst you wait for $8 to $15!
Posted by Andrew... on Dec 31, 2018
Watches | Answered on Aug 18, 2020
Contact the manufacturer/distributor
Need more detail. Model number. This should go from 4.5K to 6K EUR
Watches | Answered on Jul 20, 2020
Request time-setting instructions from Oshen.
Watches | Answered on Jul 15, 2020
Smith Wesson Chronograph Titanium Watch Logo
1 questions posted
Top Smith Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a Smith Watch Expert? Answer questions, earn points and help others
View Most Popular
Smith Watches
  • Smith Watches
Most Popular Question
watch scratches purchased
  • Watches
