20 Most Recent
Maclaren Quest Mod - Scarlet Red Umbrella Stroller Questions & Answers
My maclaren stroller has squeaky wheels, what can
clean the wheels with soupy water, clean out all mud and things in between the wheels and hinges area. Check for loose parts, cracks and worn condition, repair and replace them if you can, let the wheels dry out then spray the hinges and any moving part and source of friction them with lubricant like W40.
Hood remove
Hi Tasha
We would recommend you contact Maclaren direct for assistance -
Front wheels of maclaren quest 2016/2017 model are strugling to get into position they are being pushed.
It sounds like there may be a problem with the front wheel assembly on your Maclaren Quest 2016/2017 model stroller. You may want to try removing the wheels and reattaching them to make sure they are properly seated and aligned. If this does not solve the problem, there may be an issue with the wheel locking mechanism or other parts of the front wheel assembly. It may be best to contact Maclaren customer service for assistance with troubleshooting and potential repair options.
As for the safety straps, it's possible that they may need to be adjusted or reattached properly to prevent them from coming apart. The instruction manual for your stroller should have information on how to properly adjust and attach the straps. If you don't have the manual, you can find it online on the Maclaren website or by contacting customer service.
