20 Most Recent
Crosley CEDC392JQ Electric Portable Dryer Questions & Answers
Why is
dryer is not getting hot enough
not getting hot or hot enough? if not hot at all it's probably the thermal fuse is blown, if not hot enough you could have a blockage in the blower vent system, which could be from the blower wheel in the dryer to where it vents out of your house. if no blockage then it's probably one of 2 cycling thermostats
2/14/2016 3:47:55 AM •
Crosley...
Answered
on Feb 14, 2016
Inside part loose
if you are talking about the paddle, it is screwed to the tub from the outside in
11/4/2015 12:19:24 PM •
Crosley...
Answered
on Nov 04, 2015
My dryer won't turn on.
Your problem sounds like the door switch. You should hear a click from the switch when you open and close the door. If you don't you need to replace the switch. Here is a link to the
part.
11/26/2010 4:44:34 PM •
Crosley...
Answered
on Nov 26, 2010
Dyer
Jesse, does the door light come on? If not check the thermal fuse. You will have to open the top by pushing in on the two clips on each side. In back, on the right side of the heater you will see a thermostat and about 4 inches below the thermal fuse. Look at number 5 in the attachment. Makes sure to kill the power before going back there. You can either jump it out or ohm it out to make sure that is the problem. Part number for the fuse is LA1053.. Catriver..post back
3/14/2007 2:15:30 AM •
Crosley...
Answered
on Mar 14, 2007
