20 Most Recent LG LFX21980ST Stainless Steel Bottom Freezer French Door Refrigerator Questions & Answers
You need to remove the freezer door and basket. then remove the rails on both sides. then there is a panel at the back of the freezer. Pull at the top part of the panel and it will come out.
LG LFX21980ST... | Answered on May 23, 2014
filter needs changeing or blocked
This is most likely cause because some part of the ice maker/distribution mechanism is broken. If at all possible, remove everything from the fridge and freezer and allow the freezer to thaw. If that is not possible, you could try and remove just the ice maker to thaw it or try and thaw it while it is still in the freezer. I hope this helps and have a nice day!
LG LFX21980ST... | Answered on May 04, 2011
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
LG LFX21980ST... | Answered on Aug 28, 2010
check capacitor to compressor if ok possible bad compressor if no voltage to compressor bad board
LG Refrigerators | Answered on Nov 17, 2020
Check for a bad hard start cap/relay on compressor. If it is running check for ice on evaporator - if ice then the defrost mechanism is not working.
LG Refrigerators | Answered on Oct 14, 2020
LG brand
switch off at the wall point
wait a bit
start again
if its not in the user manual and no one can figure out why
if it still beeps some part of that unit has failed or needs to be reset
no other choice but to call out a lg repair man
LG Refrigerators | Answered on Sep 27, 2020
Could be the hinge, most likely the lower hinge. Fridge hinges usually have a plastic insert in the door to prevent metal to metal contact. This insert sometimes wears prematurely and then metal may start to make contact , thus the grinding sound. The insert can be changed fairly easily if you are so inclined.
LG Refrigerators | Answered on Sep 19, 2020
The most probable reason is leakage of refrigerant gas. You have to get it refilled and sealed by the mechanic.
LG Refrigerators | Answered on Aug 19, 2020
I did turned it off for like a 10 minutes and it worked my problem was it was beeping and no light but it was cooling
LG Refrigerators | Answered on Aug 07, 2020
LG LFX21980ST Stainless Steel Bottom Freezer French Door Refrigerator Logo
10 questions posted
Top LG Refrigerators Experts
Michael Thomas
Michael Thomas
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
LG Refrigerators
  • LG Refrigerators
Most Popular Question
er ff
  • Refrigerators
