20 Most Recent Haier HC125FVS Wine Cooler Beverage Cooler Questions & Answers
it probably has a leak & needs freon. in most cases there are no ports to check the freon level. you will have to add them. if you dont know how to do this it will be cheaper for you to go buy a new one vs. paying somone to fix it.
Haier HC125FVS... | Answered on Oct 15, 2013
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Haier HC125FVS... | Answered on Apr 13, 2011
llok in the back by compressor . also if the wirign sch is on unit find the wiring and folow to it .. repair clinic is on the right track and when you find it and replace it problem over .. it 's not hard to find . .. mm
Haier HC125FVS... | Answered on Aug 17, 2010
you will like this,same thing happened to someone i know and they went into thier local dealer and asked to borrow a key,the dealer said yes but will take a $25 deposit for the return within 48hours.
guess what.....the first key did not fit,but the third one did.....happy ending......i supose they could have taken the cooler to the dealer,but is was full of beer......
Haier HC125FVS... | Answered on Aug 14, 2010
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Hi, sounds like an "overload and relay" on the compressor.
This is the equivalent to a starter on a car. When they go bad, the compressor just does a "buzzzzz.. click" about every 5 to ten minutes. In the worst case, you may have a bad compressor, but this is less common.
It's more likely to be a relay starter problem which is usually located near the compressor, all you need do is change it.
Take care
Haier HC125FVS... | Answered on Jul 04, 2010
might be possible, depending where exactly the puncture is, but if it was repaired it would need
regassing to the correct level, you would need a professional refrigeration engineer,
Haier HC125FVS... | Answered on Dec 13, 2009
Sounds like an "overload and relay" on the compressor. This is the equivalent to a starter on a car. When they go bad, the compressor just does a "buzzzzz.. click" about every 5 to ten minutes. In the worst case, you may have a bad compressor, but this is less common. Hope this helps!
Haier HC125FVS... | Answered on Dec 06, 2009
Hi:
It should be repairable. You would need a Heating/ Air Conditioning repair shop to silver solder the hole closed, and possibly sweat on a valve to evacuate and refill the system. I would call around and ask if the shops do this sort of thing. I had a similar repair done on a window air conditioner, and it saved me money!
Haier HC125FVS... | Answered on Nov 17, 2009
Haier HC125FVS Wine Cooler Beverage Cooler Logo
26 questions posted
Top Haier Refrigerators Experts
Vernon Taylor
John Tripp
John Tripp
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Haier Refrigerators
  • Haier Refrigerators
Most Popular Question
lost keys cooler buy or
  • Refrigerators
