20 Most Recent LG LFX23961ST Stainless Steel Bottom Freezer French Door Refrigerator Questions & Answers
LG Refridge LFX23961st
LG LFX23961ST Support Manuals Warranty More LG I just used the link above to get the Manuals on your LG. On page 31, they did the following CYA statements... The defrost timer will click when the automatic defrost cycle begins and ends. The thermostat control (or refrigerator control, depending on the model) will also click when cycling on and off. Rattling noises may come from the flow of refrigerant, the water line, or items stored on top of the refrigerator . Your refrigerator is designed to run more efficiently to keep your food items at the desired temperature. The high efficiency compressor may cause your new refrigerator to run longer than your old one, and you may hear a pulsating or high-pitched sound. You may hear the evaporator fan motor circulating the air through the refrigerator and freezer compartments. As each cycle ends, you may hear a gurgling sound due to the refrigerant flowing in your refrigerator. Contraction and expansion of the inside walls may cause a popping noise. Water dripping on the defrost heater during a defrost cycle may cause a sizzling sound. You may hear air being forced over the condenser by the condenser fan. You may hear water running into the drain pan during the defrost cycle. I bolded the statement. Sounds like you are going to have to get used to the sound. Semper Fi, Z
2/1/2018 3:32:07 AM • LG LFX23961ST... • Answered on Feb 01, 2018
0answers
Why does it keep blowing fuses?
your unit either has shorted wirings , grounded compressor or fans. thanks.
3/5/2016 5:42:14 AM • LG LFX23961ST... • Answered on Mar 05, 2016
How to change the fan on a LG LFX23961ST
please specify fan for what . thanks .
3/5/2016 5:38:43 AM • LG LFX23961ST... • Answered on Mar 05, 2016
0answers
LG
Be the first to answer 4/25/2013 2:26:15 PM • LG LFX23961ST... • Posted on Apr 25, 2013Be the first to answer
0answers
Serious leaking probably coming from
Most likely the water inlet valve is no longer shutting the flow.
It's part 614A in this diagram
http://www.searspartsdirect.com/partsdirect/part-model/LG-Parts/Refrigerator-Parts/Model-LFX23961ST/3204/0161000/K0810253/00006?blt=06&prst=&shdMod=
You will have to open the unit and access the valve to see if the fault is in it or one of the pipes leading to it have burst.
8/22/2011 9:38:09 PM • LG LFX23961ST... • Answered on Aug 22, 2011
Error message: Er 1F
You have a problem with the ice room fan motor. It will not send freezing cold air to the icemaker. You will need to have a qualified technician replace the fan motor.
Good luck
6/19/2011 3:57:01 AM • LG LFX23961ST... • Answered on Jun 19, 2011
Error code is 1F -
My 2 year old LG LFX23961ST refrigerator started showing error code Er IF. In searching help here,
I found out it meant the problem was with the Ice maker Fan. When I checked the ports where the cold air blows into the Ice maker compartment, there was no cold air coming out (you have to hold the door switch in to turn on the fan). I removed the ice maker module (two screws) and unplugged it. When I closed the door, the fan started running, but was making a rattling noise. I suspected ice build up.
Emptying out the freezer compartment, I pulled the rear cover of the compartment off and found what I had suspected. Cleaned out the ice, put everything back together and Voila! Everything working again.
As I write this, I can hear ice dropping into the ice holding tray. Not sure yet why the whole ice blockage thing happened though. Will keep an eye on it. It's been several hours since the repair and no issues. All seems well. It's not rocket science. If you can use a screwdriver, you can fix it too.
5/8/2011 11:46:14 PM • LG LFX23961ST... • Answered on May 08, 2011
I have an ER 1F.
1. yes. Open ice room door (back side of left hand refrig door) and turn toggle switch on icemaker to OFF. 2. yes. Do step 1 and connect water to refrig. 3. ER IF (Error Ice room Fan) may still come up. If it does and you don't like it, you could probably avoid that by removing the fan blade from the ice room fan, located in the freezer section, behind the back wall, upper left hand corner. The error code pops up when the electronic board does not see a feedback signal from the ice room fan. Removing the fan blade should allow the motor to run, thus sending the feedback signal to the board, preventing the code from appearing.
3/21/2011 7:22:10 PM • LG LFX23961ST... • Answered on Mar 21, 2011
I need help my refrigerator
You went the wrong way on setting, go to lower setting,this should help from freezing.
2/8/2011 12:48:37 AM • LG LFX23961ST... • Answered on Feb 08, 2011
Pieces of white plastic in my crushed ice
check the ice maker,the base rots out where the water forms into ice cubes or check the tray and the auger to see if a part of it broke off and is grinding up with the ice cubes
9/25/2010 7:22:42 PM • LG LFX23961ST... • Answered on Sep 25, 2010
LG LFX23961ST Stainless Steel Bottom Freezer French Door Refrigerator Logo
39 questions posted
Top LG Refrigerators Experts
Colin Stickland
Colin Stickland
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
LG Refrigerators
  • LG Refrigerators
Most Popular Question
error code 1f
  • Refrigerators
