20 Most Recent Cuisinart CWC-1200 Wine Cooler Questions & Answers
R37 10 ohm 1/2 Watt
R38 2 ohm 1/4 watt
also change d12 1n4148
Cuisinart... | Answered on Jan 26, 2016
did you call the 1-800-726-0190
Cuisinart... | Answered on Jan 23, 2016
try the peltier unit
Cuisinart... | Answered on Jan 05, 2015
I have been all through these, and they are not very repair friendly. If it's under 3 years old Call Cuisinart, they will exchange it.
They are solid state cooled using a peltier chip cooler. There are 1 or 2 fans in the back cavity, and probably 1 inside. Remove everything from inside, and set the temp to cooling. Do all 3 fans run? If the inside fan does not run, no cooling. The fans are common 2 wire 12 volt computer fans, and available at computer parts stores that sell PC cases and components. Next is to check the cooler itself. Remove the inside rear cover. There's heatsink under the inside fan. Does it get cold when the fridge is running? If not, the next step you will need to get the back off. The Torx screws are special, but a quick slotting of the screw heads with a dremel or a hacksaw, and a regular screwdriver will remove them. Once off, note the red/black fan wires. Also see if there is a load of dirt in the heat sink. If it's plugged, no cooling. Back to the red/black wires. The fan wires are thin. The peltier cooler is heavier. Set to cool, Check for 12 volts on all 3 pairs of wires. If there's power, the fans run (inside and out) and the inside heat sink does not cool, the peltier chip is bad. It's major surgery to replace the chip, but it can be done, and there are scads of sellers on E-bay selling 60-90 watt peltier coolers that will work. They are standard millimeter square sizes, just match the thickness, 12-15 volts, and wattage (around 60-90).
If you are not getting power on the peltier cooler chip lines, there is a tiny fuse on the lower left of the circuit board. Check it.
These are not servicable from cuisinart. Even the silly screws to change the light bulb are security torx type. Fans are available at computer parts stores. Fuses at electronic supplies. The peltier chip can be had from E-bay. That circuit board is impossible to get. Any other parts are impossible to get to by the way it's built.
Thank you for using FixYa,
Cuisinart... | Answered on Sep 17, 2013
Yep...no freon. My thermoelectric disc was blown. Replaced for $6 from Ebay. Let me know if you want step by step instructions with pics.
Cuisinart... | Answered on May 03, 2013
Cuisinart CWC-1200 Wine Cooler Logo
50 questions posted
Top Cuisinart Furniture Experts
ThaMp3Doctor
ThaMp3Doctor
Nassim Koubeissi
Nassim Koubeissi
Level 1 Expert
Tom Chichester
Are you a Cuisinart Furniture Expert? Answer questions, earn points and help others
View Most Popular
Cuisinart Furniture
  • Cuisinart Furniture
Most Popular Question
looking resistor values r37 r38
  • Furniture
