20 Most Recent
Wahl 8892-002 Kennel Pro Clipper Kit Questions & Answers
Dull blades
You need to send them in to have them sharpened periodically. If you look in the yellow pages under sharpening or google it you should find places to send your blades to. Or you can buy new ones but sharpening them is definitely cheaper
Hi, I have a 'Pet Clipper Kit fot Dummies' and its
When you attach the attachment, check that it might be touching/rubbling on the movable top blade. If it is interferring with the back and forth motion of the top blade it may cause the noise you are talking of. Try moving it around to avoid this interferance.
I have a brand new pair of wahl clippers and they
check on the side for a screw to adjust the blades. It's meant to be use with a straight screw driver, you need to go left or right until it sounds perfect, otherwise it will sound weird so until it per's like a kitten keep moving that screw.
Wahl designer clippers pulling hair
Oiling blades and sharpen them will help to fix the issue. However several reasons can cause this issues such as the low power, broken blades etc. https://pakcentric.com/wahl-magic-clip-pulling-hair/
