20 Most Recent La Crosse Technology Wt 967S Metal Strap Atomic Watch Questions & Answers
There are a couple La Crosse 967 watches available on eBay. http://shop.ebay.com/i.html?_nkw=la+crosse+967&_sacat=0&_odkw=la+crosse+967s&_osacat=0&_trksid=p3286.c0.m270.l1313
If the watch doesn't come with the type of band you need, you could always bring it to a jeweller as they may be able to match you up with a compatible band for the watch.
Chris
La Crosse... | Answered on Aug 17, 2011
You will need to take this watch in to a local Certified Master Horologist. It will have to be opened and reset from the inside by shorting the appropriate contacts on the movement. It may also require a battery to operate properly, if it has not been replaced in the past 1-2 years.
If you wear this watch in the water, you need to have it pressure tested to ensure its resistance after the procedure. This is properly done with a pressure testing machine that usually is found at Horologist / Watchmaker shops only.
La Crosse... | Answered on Feb 04, 2011
this is a repair help website. we dont sell buy or value anything here
Watches | Answered on May 26, 2020
To change the clock format, visit the General section of Momentum's Settings ??, scroll down to the Clock Format option and then click 12 hour or 24 hour to the right of it. When you switch to the 12-hour format, the AM/PM unit will display for a moment and then fade away to keep the interface clean.
https://get.momentumdash.help/hc/en-us/articles/360022896993-How-can-I-change-the-clock-format-12-hour-24-hour-
https://www.youtube.com/watch?v=VfthmmTM7Oo
Watches | Answered on May 21, 2020
a jewelry store or a clock repair store
Watches | Answered on May 17, 2020
https://www.youtube.com/watch?v=Hj1lKEULXAI
Watches | Answered on May 13, 2020
Press "mode" until the hour is flashing,
Now press "start" to change the hour. When hour is correct, press "reset" and minutes should start flashing.
Press "start" to change minutes" then press "mode" again.
Watches | Answered on May 09, 2020
move the plastic button at the back slightly to the right side where it says "Time" and than adjust the time by pressing 'Mode' and 'Up/Countdown' buttons
Watches | Answered on May 02, 2020
we will send the army over for you
Watches | Answered on May 01, 2020
La Crosse Technology Wt 967S Metal Strap Atomic Watch Logo
3 questions posted
Top La Crosse Watches Experts
Ekse
Thomas Perkins
Thomas Perkins
Overmod
Are you a La Crosse Watch Expert? Answer questions, earn points and help others
View Most Popular
La Crosse Watches
  • La Crosse Watches
Most Popular Question
looking la crosse 967s
  • Watches
