20 Most Recent Timex E Tide Temperature Compass Watch T45601 Questions & Answers
I have watch, cartier serial N 17050343 , gold with diamonds, can you write me estimate price?
Timex E Tide... | Answered on Jul 22, 2019
Generally you have to open the watch to see the movement but a lot of fakes are plain workmanship flaws.
A real Cartier will not be made from base metal. It will be made from stainless steel or precious metal.
A real Cartier will most likely be built with screws in the band instead of cotter pins.
When you pull the crown to set there will be no play in the set lever. In other words when you spin it, it will begin to turn the hand immediately and there will be a slight resistance. It will not feel loose.
As stated, the best way to tell is to look at the movement. Cartier uses a high grade Swiss movement most likely marked ETA.
Timex E Tide... | Answered on Jun 16, 2019
For Compass Adjustment search on Google or FixYa
For Temperature calibration:
1. Pull the crown to most extended position (2 notches)
2. Temp hand moves to a default position
3. Move hand in + or - direction by pressing temp or tide buttons (above and below crown button)
4. When done, push crown to 0 position
(I used melting ice water to calibrate and fix to 0 deg C)
For Tide calibration:
1. Pull crown to middle position (1 notch)
2. Move hand in + or - direction by pressing temp or tide buttons (above and below crown button)
3. When done, push crown to 0 position
Hope this helps
Timex E Tide... | Answered on May 27, 2010
To convert from C to F and vice versa, use the formula C/5=(F-32)/9.
Timex E Tide... | Answered on Apr 22, 2010
go to timex website ask for instructions these can be tricky without..you can also order them through any jewelers or watch repairers...i had one for sale with instructions and its still tricky to set ..
Timex E Tide... | Answered on Mar 26, 2010
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Timex E Tide... | Answered on Feb 10, 2010
i bought a jack phone from a man needing money and i did not know you needed a unlock code can any body help so i want be out 75 dollars plz
Timex E Tide... | Answered on Jan 02, 2010
HOW TO START YOUR WATCH Quartz Movement:
To start your watch remove the plastic guard from under the crown, then press the crown in against the case. The second hand will begin advancing in one-second intervals. Some deep-depth water-resistant watches require the setting crown to be screwed in to secure water-resistance. If your watch case has a protrusion with screw threads, the crown must be screwed in after setting the watch. To screw in, push the crown firmly against the threaded protrusion and hold in while turning the crown clockwise. Continue to screw in the crown until it is tight. You will need to unscrew the crown (counter-clockwise) before pulling it out the next time you want to set your watch.
Timex Watches | Answered on May 21, 2020
put a note on Facebook and suggestions - take it to a local jeweler, go to Wallmart where they have all kinds of batteries. So, I'll try the jeweler, and I have to find a wallmart - we are 14 miles from NYC - there must be one around here - so - not solved, but suggestions thanks anyway.adriana
Timex Watches | Answered on Mar 29, 2020
Timex E Tide Temperature Compass Watch T45601 Logo
22 questions posted
Top Timex Watches Experts
Janelle Schoonover
Janelle Schoonover
STEVE yes that one
Are you a Timex Watch Expert? Answer questions, earn points and help others
View Most Popular
Timex Watches
  • Timex Watches
Most Popular Question
no instruction manual
  • Watches
