20 Most Recent White Mountain F64304X 4 Quart Ice Cream Maker Questions & Answers
I purchased a white mountain 4qt freezer about a
It sounds like the motor that actually spins the unit is starting to fail. Any time it is resistant to pressure / weight it is an indication that the motor itself it starting to give out, lose amperage, or have some other mechanical issue. My recommendation is that you call White Mountain directly and see if it is under warranty still (I believe it may be 5 years even) or if not, they can definitely help you get the part you need, or they can do the repair. Their number is:
1-800-343-0065
9/17/2010 3:30:22 PM • White Mountain... • Answered on Sep 17, 2010
I need to get a new gear box for my 4 qt White
Here is a tip that will give you the information you are looking for...
Ice Cream Maker Parts, Instruction Manuals and Recipes
http://www.fixya.com/support/r5322664-ice_cream_maker_parts_instruction
heatman101
7/17/2010 1:35:18 AM • White Mountain... • Answered on Jul 17, 2010
I have recently obtained a white mountain 4 quart
This may what you're looking for. (If it helps, invite me over to test out the results
3/31/2010 4:10:36 PM • White Mountain... • Answered on Mar 31, 2010
I can;t seem to get
Is your homemade ice cream soupy even though it's been in the freezer for hours? Before you dispose of your ice cream maker, you might want to troubleshoot and see if you can fix the problem yourself.
1.Use your cylinder bowl correctly. If the cylinder isn't handled properly, your ice cream won't set. Make sure it is dried completely after washing so ice doesn't form on the walls, make sure to leave it in the freezer overnight before making ice cream and don't leave the bowl out at room temperature before using.
2.Check your freezer door. If it isn't sealed properly, or if it's constantly being opened during the freezing process, your ice cream can't set properly.
3.Handle the ingredients correctly. Don't let the ingredients warm and don't overfill the bowl. Check the manufacturers recommendations for the maximum bowl capacity.
4.Clean and dry your machine thoroughly. Use a damp cloth on the motor assembly; never immerse. Make sure to wash the lid, blade and cylinder according to directions and make sure the cylinder is absolutely dry before freezing.
5.Contact the manufacturer's support site only after you have exhausted your options. They may walk you back through the steps you've already taken, but at best your problem will get fixed far more quickly because you eliminated the easy problems in advance.
9/6/2011 6:42:55 PM • White Mountain... • Answered on Sep 06, 2011
I NEED A HB1114 ICE CREAM MACHINE MANUAL
https://www.manualslib.com/i/ichb1114e+cream+maker.html Try this site. Let me know if it works.
12/4/2023 12:34:16 AM • Ice Cream Makers • Answered on Dec 04, 2023
What is the black liquid draining into the ice-cream canister from the motor while making? And is it still safe to eat?
No make and model provided but.... Of course it isn't safe to eat!! It is likely a mixture of oil, broken seal dust and a little metal/rust creamed with a drop of condensation. 50 years as as a chef and I wouldn't serve that or eat it. Fix it or thrown the machine away! These machines are normally 20 years old and get used 3 times every 2 years.
7/5/2023 12:17:35 AM • Ice Cream Makers • Answered on Jul 05, 2023
Ice cream maker freezes and stops turning after only 20 minutes. I set the time for 60 minutes.
If your ice cream maker freezes and stops turning after only 20 minutes, there may be a few reasons for this. Here are some things to check: Freezing temperature: Make sure that the temperature in your freezer is set to the correct temperature (around 0°F or -18°C). If the freezer is too warm, the ice cream maker may not freeze the mixture properly. Mixture consistency: Make sure that the mixture you are using is not too thick. If the mixture is too thick, the ice cream maker may struggle to turn the mixture and freeze it properly. Overfilling: Make sure that you are not overfilling the ice cream maker. Overfilling can cause the mixture to overflow and prevent the machine from freezing the mixture properly. Motor issue: If none of the above solutions work, there may be an issue with the motor of the ice cream maker. In this case, you may need to contact the manufacturer or a professional repair service to diagnose and fix the problem. As for turning on the furnace and power in your Hitchhiker II trailer, you may need to refer to the owner's manual or contact the manufacturer for specific instructions, as the process may vary depending on the model and year of your trailer.
2/24/2023 9:22:15 PM • Ice Cream Makers • Answered on Feb 24, 2023
How can I replace the fuse 16A 250V in my Buffalo Icecream maker ?
I have no idea. Are you an electrical engineer ..............
10/22/2022 7:19:14 AM • Ice Cream Makers • Answered on Oct 22, 2022
Anyone to help me with manual for Beiqi ice cream machine (model BQ323PA)
It appears to be a South African machine, so this link might work better for you than me in North America. https://www.google.com/search?q=Beiqi+BQ323PA+manual ..
10/5/2022 12:30:41 AM • Ice Cream Makers • Answered on Oct 05, 2022
Is cream charger necessary for making coffee?
There is no substitute for a cream whipper when it comes to making foams, sauces, and freshly whipped cream. These sealed canisters whip up whipped cream of the highest caliber in a matter of seconds by forcing air into the cream using compressed gas. These instruments are necessary for caf?s, bakeries, restaurants, and more since they let you to make a variety of desserts, milkshakes, fresh cakes, pastries, and cream infusions. However, how can you maximize the potential of your cream whipper? Cream whippers, which are most known for creating whipped cream that maintains its shape and texture, can also keep foams, sauces, and mixes fresh by delaying the start of oxidation. What happens if the multipurpose kitchen appliances you rely on suddenly break down? Fortunately, most problems can be swiftly resolved, so knowing how they operate will help you improve their performance when the occasion demands it.
9/14/2022 6:05:38 AM • Ice Cream Makers • Answered on Sep 14, 2022
Cooks essentials 700 ml ice cream maker
limited info generic answer circuit problem -paddle connection fail--cog/gear fail -motor fail need to examine unit to narrow down problem since their many to choose from
8/1/2022 2:46:33 PM • Ice Cream Makers • Answered on Aug 01, 2022
Can anyone help me get my Taylor 150 Ice Cream machine started please?
If it was fine before stored away, then either the power is not getting to the machine, (rodent damage or corroded contacts) or there is a control fault.
7/16/2022 5:58:26 PM • Ice Cream Makers • Answered on Jul 16, 2022
Instructions and recipes for Toastmaster ice cream maker
The manual is here
Toastmaster Ice creamn maker model 6701, use and care ...
https://manualzz.com > ... > Ice cream makers Toastmaster Automatic Ice Cream Maker Use and Care Guide Recipe Book Model 6701 IMPORTANT SAFEGUARDS When using electrical appliances, basic safety .. ..
7/14/2022 7:55:41 PM • Ice Cream Makers • Answered on Jul 14, 2022
White Mountain F64304X 4 Quart Ice Cream Maker Logo
3 questions posted
Top White Mountain Ice Cream Makers Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Are you a White Mountain Ice Cream Maker Expert? Answer questions, earn points and help others
View Most Popular
  • White Mountain Ice Cream Makers
Most Popular Question
purchased white mountain 4qt freezer
  • Ice Cream Makers
