20 Most Recent Crosley 40-pint Dehumidifier Questions & Answers
Need float switch that cuts
Without a Model Number or Part Number it's hard to help you. But here are three links, where you can find the float switch, if it's still available. You'll definitely need the Model Number to find anything.
http://www.apwagner.com/index.php?main_page=page&id=148
http://www.appliancepartspros.com/crosley-dehumidifier-parts.aspx
http://www.partselect.com/Entry.aspx?Source=GAWS&Brand=Crosley&Term=crosley+dehumidifier+parts&gclid=CIzJ3ZvR4KgCFcV95Qodnh3C0g
Hope this helepd you. Please let me know. Thanks.
5/11/2011 7:29:35 PM • Crosley 40-pint... • Answered on May 11, 2011
Unit run continueously... but produces no water in
It sounds like a refrigeration problem possibly a leak in the system or compressor is not kicking on. Either way its probably cheaper to replace the dehumidifier.
5/10/2011 10:13:24 PM • Crosley 40-pint... • Answered on May 10, 2011
The fan runs but the
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifierDehumidifier is running but no water is in bucketheatman101
3/30/2011 2:21:23 AM • Crosley 40-pint... • Answered on Mar 30, 2011
No water is cllecting
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
5/17/2010 3:16:01 PM • Crosley 40-pint... • Answered on May 17, 2010
Crosley Dehumidifier won't run... has not been used much
Here is a tip that I wrote to help people with just that dehumidifier problem..
Dehumidifier2_bing.gif Problem It shows Bucket Full
http://www.fixya.com/support/r4688381-dehumidifier_problem_shows_bucket_full
heatman101
5/17/2010 3:02:30 PM • Crosley 40-pint... • Answered on May 17, 2010
Crosley dehumidifier does not collect water.
heatman101
5/14/2010 1:05:07 PM • Crosley 40-pint... • Answered on May 14, 2010
Just started for the summer and it keeps freezing
Here is a tip that will help you...
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
4/30/2010 2:55:05 AM • Crosley 40-pint... • Answered on Apr 30, 2010
2answers
Collecting no water
My crosley dehum. acted the same way. It turned out to be a bad defrost thermostat on the evaporator coil.
9/10/2008 3:26:56 PM • Crosley 40-pint... • Answered on Sep 10, 2008
Dehumidifer - Working??? Not Sure.
if you can verify that the compressor is still active (is there a noticeable hum or buzz and / or do the room lights slightly dim during power on?) then the most likely problem is a loss of freon. if the compressor never turns on, then a faulty humidistat is likely...an electrician can run a test of this by "jumpering it out" to force on the compressor motor.
5/20/2007 4:14:48 AM • Crosley 40-pint... • Answered on May 20, 2007
0answers
I have a Crosley Model
It may very well be that you have the humidity extraction level set to high. Lower it to 32-35%. If you have a manual unit, set the control to Maximum. Since it's a basement application, raising the unit up off the floor on to a sturdy table or counter top that can handle the weight of the unit, plus a full bucket of water, may also solve the problem. As, the air temp at floor level is colder than at chest or shoulder level. Dehumidifiers do not work well at temperatures between 40 - 60 degrees F. Unless you have what's called a Low Temp Model. They are specifically designed for basement applications.
Hope this helped you to troubleshoot and solve the problem
7/3/2011 4:16:56 PM • Crosley... • Answered on Jul 03, 2011
For some reason the coils
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
6/5/2011 12:30:01 AM • Crosley... • Answered on Jun 05, 2011
Crosley model CDH40L, ser.# 01M30208961 My
There must be some sort of deformity on the fan blade and this makes it unbalance. Unbalanced fan blade will surely affect the bushing of the fan motor which will tend to over heat during operation. You better replace both the fan and the blade.
5/26/2011 11:57:26 PM • Crosley... • Answered on May 26, 2011
We have a 40-pt Crosley
Shinn, I'd say you've gotten your monies worth out of 6 year old dehumidifier. Most of the time, it's more expensive in the end, to repair one than it is to purchase a new one. With that said, I'd vote for purchasing a new one. Just take as good of care of the new one as your did the old one. Obviously, you performed preventive maintenance on the old one and that's very important. Which makes you the exception to the rule, that most consumers don't take care of what they have and are astonished when an appliance fails.
Keep up the good work!
3/26/2011 4:46:59 PM • Crosley... • Answered on Mar 26, 2011
2answers
Humidity level keeps blinking on display , is that normal on the Albert dehumidifier
What does the user manual say about this?
12/3/2022 4:19:53 PM • Dehumidifiers • Answered 13 minutes ago
Crosley 40-pint Dehumidifier Logo
Popular Tags
18 questions posted
Top Crosley Dehumidifiers Experts
Gil Shultz
ADMIN Andrew
ADMIN Andrew
ray gallant
Are you a Crosley Dehumidifier Expert? Answer questions, earn points and help others
View Most Popular
  • Crosley Dehumidifiers
Most Popular Question
crosley dehumidifier not collect water
  • Dehumidifiers
