20 Most Recent Timex T5G341 Sports Radio Control Watch Questions & Answers
ask your watchmaker to remove/disengage the alarm spring
Timex T5G341... | Answered on May 10, 2014
the problem of your watch is only the battery.. bring it to watch service center for replacement of battery. i'm happy to help you!
Timex T5G341... | Answered on Aug 01, 2011
Thank you for contacting FixYa.<br /> You can actually go to Timex for this at :<br /> http://www.timex.com/info/Product_Instruction_Guides_Downloads<br />Best regards.<br /> Jewel
Timex T5G341... | Answered on Aug 31, 2010
To change from 24 hour to 12 hour, you hold down the "Mode" button until it switches from 24 hour to 12 hour or vice versa. To change the time zone, you hold down the "Set" button until the time zone that you set it in flashes (like "LAX" on my watch). Then you press the "Receive/Start/Stop" button to choose the specified time zone you want. To set for daylight savings time ("DST" on the watch), after holding the "Set" button and having the time zone flash, you could press the "Mode" button. It will give you a few options for the daylight savings time (Auto, On, or Off). I chose the "On" option, which immediately changed for daylight savings time. If you manually want to change the time, you could hold down the "Set" button and keep pressing the "Mode" button until the time starts flashing on your watch, then pressing the "Receive/Start/Stop" button until you change it to the time that you want. You could also set the watch to beep or chime after pressing the set button if you wanted to know that piece. You hold down the "Set" button when you are done to get it to stop flashing. These instructions worked for my Timex T5G341 Universal Radio Control Watch. I hope this helps.
Timex T5G341... | Answered on Mar 14, 2010
You could change between 12 and 24 hour by pressing the "Mode" button and the "Receive/Start/Stop" button at the same time. I still cannot figure out how to reset for Daylight Savings Time, though.
If it is 1 hour out it could be on daylight saving time setting (DST).
If you haven't got any instructions you can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Timex T5G341... | Answered on Feb 15, 2010
Go to timex.com choose country then click on the help tab at the top of the page. You will find a tab for manuals and downloads on the left hand side.
Timex T5G341... | Answered on May 02, 2009
battery should always be original otherwise it will destroy your watch.dont try to put the battery yourself give it to an company autherised shop and allow them to put it
Timex T5G341... | Answered on Jan 12, 2009
HOW TO START YOUR WATCH Quartz Movement:
To start your watch remove the plastic guard from under the crown, then press the crown in against the case. The second hand will begin advancing in one-second intervals. Some deep-depth water-resistant watches require the setting crown to be screwed in to secure water-resistance. If your watch case has a protrusion with screw threads, the crown must be screwed in after setting the watch. To screw in, push the crown firmly against the threaded protrusion and hold in while turning the crown clockwise. Continue to screw in the crown until it is tight. You will need to unscrew the crown (counter-clockwise) before pulling it out the next time you want to set your watch.
Timex Watches | Answered on May 21, 2020
put a note on Facebook and suggestions - take it to a local jeweler, go to Wallmart where they have all kinds of batteries. So, I'll try the jeweler, and I have to find a wallmart - we are 14 miles from NYC - there must be one around here - so - not solved, but suggestions thanks anyway.adriana
Timex Watches | Answered on Mar 29, 2020
https://www.timex.com/watch-manuals.html
Timex Watches | Answered on Mar 19, 2020
Battery issue is my best guess, have it changed!
Timex Watches | Answered on Oct 06, 2019
Timex T5G341 Sports Radio Control Watch Logo
13 questions posted
Top Timex Watches Experts
Janelle Schoonover
Janelle Schoonover
STEVE yes that one
Are you a Timex Watch Expert? Answer questions, earn points and help others
View Most Popular
Timex Watches
  • Timex Watches
Most Popular Question
cannot change from 24 hour 12 hour
  • Watches
