20 Most Recent Bunn CWTF 15-3 Coffee Maker Questions & Answers
The machine isn't just overfilling, it does not
Remove the front panel and use the instructions there to set volume, if that does not work then the level board is damaged.
9/1/2015 5:00:25 PM • Bunn CWTF 15-3... • Answered on Sep 01, 2015
Bunn CW series slow water flow
delime the sprayhead and the reservoir drain in the top with a deliming spring or a screwdriver
1/28/2015 4:14:23 AM • Bunn CWTF 15-3... • Answered on Jan 28, 2015
tip
Bunn coffee brewer brews too slow?
lime builds up on the metal surfaces where the hot water cools down or evaporates, such as the sprayhead, the waterline to the sprayhead, the reservoir inlet, or the insides of the tank. the sprayhead and reservoir inlet buildup will restrict flow and extend brew time and may even not brew through all of the grounds. to fix: 1. remove the top of the brewer. the reservoir is right on top and the drain looks like a nut with a hole in it. lime will plug this up. using a deliming spring or even a philipshead screwdriver, push through and twist to get rid of the lime. 2. unscrew and remove the sprayhead and bore the lime out of the holes with a small flathead screwdriver or a paperclip. 3. if necessary, unscrew the reservoir drain nut, place it and the sprayhead in a cup of straight vinegar. for more stubborn lime, use CLR, but wash and rinse thoroughly. 4. if you have a deliming spring, push it through the outlet waterline to the sprayhead all the way past the 2 elbows and pull in and out, removing any lime buildup. 5. rinse parts, reassemble the reservoir, and brew a little without the sprayhead first to get rid of any loose lime. then put sprayhead on and run a test brew. if it brews short or too much, see tip for recallibrating
When making coffee, the water only fills to less
you'll have to recallibrate. use a 64 ounce measuring cup and follow the instructions on the inside of the front panel.
1/15/2015 3:28:44 PM • Bunn CWTF 15-3... • Answered on Jan 15, 2015
Bunn coffee maker heating element wont turn off
thermal fuse is blown. it is located in the top, right rear of the machine in what is now browned tubing. you can either bypass the fuse with a jumper, or get a new part through bunn (800) 352-BUNN (2866)
1/15/2015 3:27:05 PM • Bunn CWTF 15-3... • Answered on Jan 15, 2015
Hot water is comeing out of the spot slow
delime the sprayhead holes with a paperclip, and the trough drain inside the top with a screwdriver. this will ensure proper flow
1/15/2015 3:26:28 PM • Bunn CWTF 15-3... • Answered on Jan 15, 2015
My Bunn CWTF-DV-3Tisleaking water from the top right corner of my machine,and has just started leaking at the base of where the bottom burner is. Could you please help,as we have no technicians were w
open the top. there is a trough drain that gets limed up. using a phillips head screwdriver, push through and twist, thereby removing the lime and ensuring proper flow. if water can't get through, it may overflow over the sides of the trough. also look behind the trough to the top of the tank and see if there is any water damage around the seals. if there is, replace the seals
1/15/2015 3:08:24 PM • Bunn CWTF 15-3... • Answered on Jan 15, 2015
I need to ship a 3 burner BUNN CWTF 15-3. How do I drain the water out?
You can take the lid off and unscrew the nut that holds the water tray. Then take a 3/8 hose to siphon the water out of the machine.
6/15/2013 3:35:40 PM • Bunn CWTF 15-3... • Answered on Jun 15, 2013
Bunn F15 not brewing
Might be a bad solenoid. Check voltage going through the fill solenoid. If voltage is there at around 110, check if water is filling the fill pan. If no water is filling and you have the correct voltage. its a bad solenoid.
6/5/2011 7:06:18 PM • Bunn CWTF 15-3... • Answered on Jun 05, 2011
Just installed a Bunn cwtf15-3
Remove the front panel and make sure the pressure stat is turned up to max and back it up 1/4 way. If you have done that already then remove the top and check the thermostat and the inline fuse.
1/20/2011 3:03:00 AM • Bunn CWTF 15-3... • Answered on Jan 20, 2011
Our Bunn CW series three burner is over filling.
needs service tech to adjust.
(Do it yourselfers can adjust the black knob down from 2.5 to about 2 mins. Digital timers have instructions in back of the front panel. CAUTION!! There is high voltage present. Pull out the plug! Safer to just have it serviced.)
2/10/2010 11:10:51 PM • Bunn CWTF 15-3... • Answered on Feb 10, 2010
I want to increase the amount of water used to
as far as I know, no i have one as well
8/4/2009 9:47:58 AM • Bunn CWTF 15-3... • Answered on Aug 04, 2009
Our Bunn CWTF15 three burner is over filling.
There is a timer inside the front panel re-just the timer with an empty coffee pot right up to the top edge with water only.
if not successful let me know and I'll go further with your problem.my email address [email protected]
God Bless have a nice day.
Dickson
7/2/2009 1:25:40 AM • Bunn CWTF 15-3... • Answered on Jul 02, 2009
Have a Bunn CWTF, when the switch is pushed and water begins to flow thru the basket, there is a small amount of water that begins to puddle on top of the left tank (right does it also, but less).
Leaking from top of tank; Call for service as this is an electrical hazard. *** the following is for information only. *** * Replace any worn gaskets and silicone tubes. * There may be cracks in the metal pipes. Hard to see, but there, if you remove the lime deposits. * check the top tray nut if the gasket to the tank is missing. It's about an 1-1/4" round washer with about a 3/4" hole. Usually made of white silicone rubber. It seals the fill tray to the tank. Leaks often. * Bunn equipment can last quite a few years (decades?) but the gaskets do get hard and the tank needs to be water tight to work properly. Since this is already an old brewer and you've saved money rebuilding it. Suggest going further by replacing all gaskets. Yes they do need to be snug with no cracks. Aloha, ukeboy57
1/20/2018 8:24:54 AM • Bunn CWTF Coffee... • Answered on Jan 20, 2018
Water keeps running out of shower head of my bunn cw series coffee brewer
see callibration tip for bunn cwtf
1/28/2015 4:25:45 AM • Bunn CWTF Coffee... • Answered on Jan 28, 2015
How to descale Bunn CW15-APS coffee maker
delime the sprayhead and reservoir drain (in the top) with a deliming spring or a screwdriver. to delime the tank, put a half gallon of vinegar in the top and catch the hot water as it comes out of the sprayhead. leave it sit for about 20 minutes and brew at least 8 times (w/o coffee) or until you can no longer taste vinegar
1/28/2015 4:25:18 AM • Bunn CWTF Coffee... • Answered on Jan 28, 2015
Warming plate and light stopped working on Bunn coffee maker
replace the switch
1/28/2015 4:20:47 AM • Bunn CWTF Coffee... • Answered on Jan 28, 2015
Bunn water level
What about Bunn water level? Too high? Too low? Not filling? Leaking?
11/25/2014 9:21:13 PM • Bunn CWTF Coffee... • Answered on Nov 25, 2014
I have an Bunn model GRX-B datecode 304009 that leaks at the bottom, what can be done about it
Most likely cause is that the seal between the water reservoir and the tank is leaking. Not uncommon. If you can find a replacement seal go for it, otherwise the old one can be made serviceable by coating both sides with a thin bead or layer of clear silicone. Allow to cure for 24 hours before powering the coffee maker back up.
11/23/2014 8:10:01 PM • Bunn CWTF Coffee... • Answered on Nov 23, 2014
Bunn CWTF 15-3 Coffee Maker Logo
Popular Tags
15 questions posted
Top Bunn Coffee Makers & Espresso Machines Experts
john h
ADMIN Canada
ADMIN Canada
Kolbrun...
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
CWTF Bunn
  • CWTF Bunn
Most Popular Question
just installed bunn cwtf15 3
  • Coffee Makers & Espresso Machines
