20 Most Recent Seiko SGG786 Watch for Men Questions & Answers
Hi Jeffrey, Put stem into "set hands" position and adjust hands to the 12:00 position. Day and date should advance at or close to that time. If you pass 12:00 and there's no change continue rotating another 12 hours and they should advance. Once youv'e found that there's midnight so if you're setting the time at say four (4:00) in the afternoon (pm) you will neew to rotate the hands so around the dial so they pass 12:00 once more then four hours more to 4:00. Now I assume by bilingual you mean that the day ring has like Mon (monday) and Lun for Spanish or the like. In this case if it's showing the wrong languare set the crown (winder) to the first position (second posn is "set hands) and rotate winder eithr clockwise or anticlockwise. Once you discover how to advance the day ring just set it to the correct day/language you want and press the crown home. Hope this solves your problem. If the advances are changing at some obscure time like 8:40 or something it's because the hands pave been located incorrectly and would need correcting by removing movement from the case.
Seiko SGG786... | Answered on Jul 24, 2009
https://drive.google.com/file/d/1z-BU-3DNcdDWKJvUle75FOmiTGYLL5cr/view?usp=drivesdk
Seiko Watches | Answered on Jan 10, 2021
you should be able to set it with the stem if your having trouble it may have to go into seiko the solar watches can be very complicated
Seiko Watches | Answered on Dec 10, 2020
Try putting it under a lamp at bedtime and you need to wear it and keep in the light at all times during the day, if this does not remedy it it will need a new cell that needs to be done at the company. our store can do that for you, [email protected] .com
Seiko Watches | Answered on Nov 11, 2020
You can follow these steps to reset your watch manually:
  1. Press and hold "SET" button for 2 seconds until the hour digit.
  2. Press "ADJUST" button to change the value of the hour digit.
  3. Press the "SET" button once, the minute digits will flash.
  4. Press the "SET" button once, the second digits will flash.
  5. Press the "SET" button, "12H" or "24H" will flash.
Seiko Watches | Answered on Jun 24, 2020
Hi Rsomekh-
I found this link.
https://www.manualslib.com/manual/617445/Seiko-Wp7500.html#manual
On page 35, there is a section on "Setting the LCD Contrast".
Hope this helps.
Seiko Watches | Answered on Nov 28, 2019
Go to: http://www.seiko.com.au/support/instruction-booklets
Seiko Watches | Answered on Aug 26, 2019
I found a way to get my second hand ‘unstuck’. It would only wiggle when I pressed the button to show the charge. After replacing the capacitor and reassembling very carefully, I pulled out the crown halfway and turned it to advance the date by several days at once. The second hand started moving again right away. It was advancing a second at a time not two, so it had charge. When I checked the amount it showed almost full (new capacitor was already charged).
Seiko Watches | Answered on Aug 17, 2019
Seiko SGG786 Watch for Men Logo
Popular Tags
1 questions posted
Top Seiko Watches Experts
Lisa Christine
Lisa Christine
ray gallant
Ray
Are you a Seiko Watch Expert? Answer questions, earn points and help others
View Most Popular
Seiko Watches
  • Seiko Watches
Most Popular Question
date changes during day
  • Watches
