20 Most Recent Seiko Pulsar Bracelet Watch Questions & Answers
Jeweler can repair that.
Seiko Pulsar... | Answered on Oct 27, 2009
There are no mystery at all. If you leave flat battery inside watch for a long period of time, battery may explode or leak. Leakage is happening most often and when it happens it is allmost invisible to naked eye.
However, the leaking solution consists of various chemical solutions and they react with metal, alloy, brass, led and other metal parts of which watch movement is made. This process is called ''oxidation'' and it works like rust on metal. You can see it wth a help of magnifier and it looks like tiny fungus layer all over various metal parts.This layer do not transmit electricity as well.
Sometimes it's possible to repair watch (depending on how much damage has been done), but in my experience few times I came across the situation that new movement replacement was needed.
All watch manufacturers are advising not to leave watches with flat battery in and if not changed for the new one ASAP, get the flat battery out of watch.
All you can do is to find your watch repair shop and ask what's possible to do. Speak to the watchmaker, not the jeweller.
Best of luck with your watch.
P.S. Please note that I am just explaining what the problem is and your rating or feedback should not be based on your negative emotions.
Seiko Pulsar... | Answered on Sep 17, 2009
Enquire with either a Pulsar dealer or a watchmaker they may be able to get it for you. If you have a trade supplier near you they may also be able to order one if available.
Seiko Pulsar... | Answered on Jul 25, 2009
You can follow these steps to reset your watch manually:
  1. Press and hold "SET" button for 2 seconds until the hour digit.
  2. Press "ADJUST" button to change the value of the hour digit.
  3. Press the "SET" button once, the minute digits will flash.
  4. Press the "SET" button once, the second digits will flash.
  5. Press the "SET" button, "12H" or "24H" will flash.
Seiko Watches | Answered on Jun 24, 2020
Seiko website. Just put you calibre code. Looks like your 6F24 is a copy.
www.seikowatches.com > Home > Customer Service > Instruction
Instruction of 3X22 (GPS Solar) Handy Manual for Astron : English. 4. 4F32 ... Instruction of 8R28 (Automatic Chronograph) : English. 8R39. Instruction of 8R39 ...
Seiko Watches | Answered on Mar 30, 2020
Google (seiko)(5T50-6A09)(manual) without parens OR contact Seko directly to request it.
Seiko Watches | Answered on Dec 16, 2019
Hi Rsomekh-
I found this link.
https://www.manualslib.com/manual/617445/Seiko-Wp7500.html#manual
On page 35, there is a section on "Setting the LCD Contrast".
Hope this helps.
Seiko Watches | Answered on Nov 28, 2019
Google (seiko)(qhl400slh)(manual) without parens OR contact Seiko directly to request it.
Seiko Watches | Answered on Oct 30, 2019
Go to: http://www.seiko.com.au/support/instruction-booklets
Seiko Watches | Answered on Aug 26, 2019
The second hand should start automatically if the battery was replaced correctly.
Seiko Watches | Answered on Aug 17, 2019
Seiko Pulsar Bracelet Watch Logo
3 questions posted
Top Seiko Watches Experts
Marvin
Marvin
Vernon Taylor
Are you a Seiko Watch Expert? Answer questions, earn points and help others
View Most Popular
Pulsar Seiko
  • Pulsar Seiko
Most Popular Question
new battery still not working
  • Watches
