20 Most Recent
Invicta Automatic Watch Questions & Answers
New automatic watch keeps stopping
You can wind this watch until it is snug. If it does not continue to run during normal wear then you should have the watch looked at. The swing weight or main spring maybe malfunctioning. If you can return it under warranty that would be best.
3/9/2010 5:56:14 AM •
Invicta...
Answered
on Mar 09, 2010
My Invicta reserve speedway won't keep time but the stop watch works need help
If the stopwatch is working but the timekeeping is not accurate on your Invicta Reserve Speedway watch, there could be several possible causes for the issue. Here are some steps you can take to troubleshoot the problem:
- Check the battery: A weak or dying battery can cause timekeeping issues. Try replacing the battery with a fresh one to see if it helps.
- Check the movement: If the battery replacement doesn't solve the issue, the movement (the internal mechanism that powers the watch) may be damaged or worn out. A professional watchmaker can diagnose the problem and repair or replace the movement if necessary.
- Check the setting: Make sure the watch is set to the correct time and time zone. You can refer to the manual or instructions for your watch on how to set the time and time zone.
- Magnetization: Sometimes, exposure to magnetic fields can interfere with the timekeeping of a watch. If you suspect that your watch has been exposed to a strong magnetic field, take it to a professional watchmaker for demagnetization.
- Water damage: If your watch has been exposed to water or moisture, it can cause damage to the movement and affect the timekeeping. You can try drying out the watch and replacing the battery, but it may require professional repair.
If none of these steps resolve the issue, you may need to take your Invicta Reserve Speedway watch to a professional watchmaker for diagnosis and repair.
What size battery for my invicta model 10404
The SR721SW silver oxide coin cell and 370 / 371 batteries will be the batteries. Unless stated otherwise on the Invicta website or by an authorized retail official, do not look for other batteries.
Watch Battery for Invicta 11879?
Tip & How-To about Watches
Changing Watch Batteries
Lots of posters ask "what is the battery in my (name of watch)" with a view to changing it yourself. This is a bad idea for many reasons. You don't have the tools or knowledge to remove a rotary screw on back, or the gasket sealant for a waterproof watch. Some fashion watches have 4 traditional screw and need professional grade jeweler screwdrivers. Also, there are about 20 batteries commonly used in watches, in various sizes and internal technology, Lithium Ion, Silver Oxide and Manganese Alkaline. If you buy them, you generally have to buy 10!
Don't sweat the details. Just take the watch to your local jeweler. They have all the batteries at hand and the tools to remove the back. It is done whilst you wait for $8 to $15!
Posted by ADMIN... on Dec 31, 2018
