20 Most Recent Zefal Air 3 Floor Pump Questions & Answers
How do you attach zefal z console to bike?
After a call to the customer service people who were more confused than I was, I figured out how to mount the bracket to the handle bar. Believe it or not the Zefal guys did not have an instruction manual on the product they sell. So here is how it works... You have to run the hard plastic strap around the handle bar and push it into a gap between the plastic nut . It's such a small gap that you will have award time finding it. Once you tighten the plastic nut the strap will advance slowly until the end will come appear on the other side. That's all there is to it. Now why the heck could they not put a picture of this on the box? Perhaps job security for the Zefal guys?
7/24/2012 10:41:34 PM • Zefal Cycling • Answered on Jul 24, 2012
How to attach zefal z console
Linda, I was having problems with the installation also, but my husband finally figured it out. Just start the end of the strap at the screw, as you tighten the screw with the Allen wrench it will thread the end thru and will get tighter around the post of the bike. It works perfectly and now I can use the GPS on my iPhone to record my rides. Hope this helps!
6/15/2012 8:15:05 PM • Zefal Cycling • Answered on Jun 15, 2012
Do you have step by
Place the end of the air hose nozzle from the pump on the tire valve.
Flip the lever on the side of the air nozzle straight up to lock the nozzle to the tire valve.
Hold the cylinder in one hand. Grab the end of the pump by its handle.
If the handle flips up, flip it up and turn it sideways and let the handle slip into your palm.
The stem of the handle should be extended between your middle finger and your ring finger.
Pull the handle straight out.
You will hear a slight hiss as the air is pulled into the bottom cylinder
and air is expelled out down the hose at the same time.
Push down on the handle to expel the air into the hose from the bottom of the cylinder.
Continue pushing and pulling up on the handle as you hold the pump in your hands until the tire is firm to the touch.
Remove the air nozzle from the tire valve.
Place a tire-pressure gauge on the valve to check the pressure.
Continue pumping and checking the tire to inflate it to the recommended pressure that is marked on the side of the tire.
5/14/2011 11:33:09 PM • Zefal Cycling • Answered on May 14, 2011
I can't get my Zefal
If it is a dedicated presta pump, there should be a threaded cap on the head where it attaches to the valve stem - it has a hole through it to allow the stem through. Tighten that stem slightly and it should compress the rubber enough to hold on. But don't tighten too much or it will be hard to get off.
The head holds on with a rubber donut under that cap. By tightening the cap, the donut gets compressed and closes the hole tighter.
10/18/2010 1:23:38 PM • Zefal Cycling • Answered on Oct 18, 2010
0answers
2answers
What size is the seat post on the Next px 6.0 bicycle?
The Next PX 6.0 uses a 27.2mm seat post.
1/1/2024 12:50:08 PM • Cycling • Answered on Jan 01, 2024
My gt mach one serial number is SA8Y01976 NEED TO KNOW THE YEAR AND WHERE WAS MADE
serial number is 12900243GT m one. Can anyone tell me the year?
10/24/2023 4:03:47 PM • Cycling • Answered on Oct 24, 2023
3answers
Where can i get a left paddle for my Mongoose XR-75 Mnt. bike?
clean your garage and you will have it. or try bike shops.
10/5/2023 4:17:26 PM • Cycling • Answered on Oct 05, 2023
My bicycle's pedal moves before the wheel. I tried reassembling the chain and the wheel. P.s my bicycle doesn't have a mechanical gear
If your bicycle doesn't have mechanical gears, the issue might be related to the freewheel or cassette, depending on your bike's specific setup.
10/3/2023 10:24:25 AM • Cycling • Answered on Oct 03, 2023
Tomahawk E Series Exercise bike loud peddling sound
Standard WD40 is just a 'quick fix' as it isn't an actual oil unless the can is clearly labelled as "Bike All Condition Lubricant". It'll be best to buy a proper light oil like 3in1, 151 Super oil or an actual chain lube. This 'clickey' noise. Is it random and happening every so often or is it a constant, regular click that changes with the speed your pedalling at? Check for slack in the chain. as you wiggle the chain up and down there should only be about a centimetre of movement in the chain. If it's too slack or too tight it can make strange noises. Check the axle bolts and nuts to make sure they're not loose. Check the wheel is mounted straight. If it's turned left or right the chain will 'skip' as it's slightly missing the cog teeth on the wheel. Use the frame at the rear end of the wheel as reference and measure how far the side of the wheel is from the frame on both sides. It should be about the same both sides.
9/22/2023 12:16:04 PM • Cycling • Answered on Sep 22, 2023
New Balance 6100 Recumbent Bike making a clanking noise when pedaling
I have done a tremendous amount of research on this problem. New Balance (Fitness Quest) is out of business as of late 2012 and no parts are available. The main bearing or crank bearing set is 100% compatible with Proform part number 295560. Since New Balance put their name on this product, they have stated they will reimburse customers for the repairs.
4/5/2023 11:21:09 AM • Cycling • Answered on Apr 05, 2023
I have a 1986 Ford Ranger 2.3L. i cannot locate crank sensor. All i can find in blogs is somewhere by the front pully. well i have it all trorn down and I cannot locate it at all Could it be by bellh
dont think you have one believe 89 started having them ------https://www.justanswer.com/ford/1e5mr-1986-ford-ranger-2-9-liter-spark-fuel-pressure.html
4/2/2023 1:44:37 PM • Cycling • Answered on Apr 02, 2023
What size pedal and shaft do I need for my Nishiki Tamarck bike?
You are using the wrong terms although 'pedals' is correct. The 'shaft' is called a 'crank' or a 'crankset'. https://www.google.com/search?q=Nishiki+Tamarack+crankset+and+pedals General Parts https://www.google.com/search?q=Nishiki+Tamarack+parts+website ..
3/31/2023 1:29:29 AM • Cycling • Answered on Mar 31, 2023
2answers
A manual for a manual for a Genesis model gs52686 men's bike a V2 100
Il est possible de trouver un manuel pour le v?lo Genesis GS52686 V2 100 en visitant le site web du fabricant ou en contactant directement le fabricant pour demander un manuel. Il est ?galement possible de trouver des informations sur ce v?lo sur des forums de discussion ou des sites web sp?cialis?s dans les v?los. Il est recommand? de v?rifier si le manuel est disponible en ligne ou de demander une copie imprim?e aupr?s du fabricant. Il est important de noter que les r?glages de la fourche de suspension et de la suspension arri?re peuvent varier en fonction du poids, de l'exp?rience et des pr?f?rences de conduite de chaque cycliste. Il est recommand? de consulter un m?canicien ou un expert en v?los pour obtenir des conseils sur les r?glages appropri?s pour votre v?lo.
3/14/2023 6:23:13 AM • Cycling • Answered on Mar 14, 2023
Zefal Air 3 Floor Pump Logo
1 questions posted
Top Zefal Cycling Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Tony Parsons
Tony Parsons
Are you a Zefal Cycling Expert? Answer questions, earn points and help others
View Most Popular
Zefal Cycling
  • Zefal Cycling
Most Popular Question
attach zefal z console bike
  • Cycling
