20 Most Recent Brother LC51BK Print cartridge, Inkjet Print Technology, Black and Color Print Color, Duty Cycle, 400 Page Color, 500 Page Black, For use DCP130C, MFC240C, MFC440CN, MFC665CW, MFC845CW, MFC2480C, MFC3360C, MFC5460CN, MFC5860CN Fax Machines, FAX1360, FAX1860, Questions & Answers
Here some relevant solutions to fix this error. The Brother Printer in Error State Windows 10, unable to print documents or incapable to connect to the printer? Here every possible solution to fix Brother Printer in Error State Windows 10.
Several windows users report After Recent windows 10 fall creators update or Install the latest updates connected printers stopped working or getting Printer in Error State in windows 10 problem.
4 Easy Ways to fix Brother Printer In Error State Windows 10:-
1. Reboot Your Brother Printer.
2. Use the Parallel Port.
3. Connect Printer Via Ethernet wire.
4. Check and Re-connect to Wi-fi Network.
The Brother Printer In Error State Windows 10 is a very harmful error this error is very annoying. If you want a full solution to this error check this blog and follow the steps given in the blog. We provide online support to any problem with Brother printer Errors.
Brother LC51BK... | Answered on Jun 29, 2020
It is possible the ink carriage and print head are very dirty and needs servicing.
Brother LC51BK... | Answered on Aug 26, 2014
See Step 15 in online instructions at the link below:
http://www.shareyourrepair.com/2015/08/how-to-fix-brother-mfc-8950-replace-parts-pf-kit-1-error.html
Step 15: Reset the PF Kit 1 Counter This will clear the "Replace Parts PF Kit 1" error that keeps coming up.
Step 15a: From the main menu simultaneously press both the 3 and 9 keys once.
You must access the secret reset menu to do this. If you don't time it correctly you will set the number of copies. If you do that just press the Stop/Exit button and try again. You DO NOT hold the keys down, just simultaneously press them once:
Simultaneously press the 3 and 9 buttonsIf you do it correctly, you will see the reset menu on the display:
The Secret Reset Menu
Step 15b: Tap "PF Kit1" on the screen.
Tap PF Kit1It will double check and ask you if you want to "Reset PF Kit1?" Tap "Yes."
Tap YesIt should then say "Accepted" to let you know that the counter has been reset:
After tapping yes it will say "Accepted"To get out of the Reset Menu press the Stop/Exit button:
Press the Stop/Exit button to get out of the Reset Menu
Brother Office... | Answered on Jun 30, 2020
here is the manual page for troubleshooting the error 1 i would check or the lose wires first and foremost along with the unplug and replug everything and return on the unit
Brother Office... | Answered on Jun 25, 2020
https://www.youtube.com/watch?v=di9K38FrnNQ
Load the document that you wish to scan into the Brother printer. Tap on the Scan button on the printer's control panel and select Scan To PC option. Choose the File option and click on Start Black or Start Color to begin scanning the document.
Brother Office... | Answered on Jun 24, 2020
  1. Place the Brother machine within range of your WPS or AOSS™ access point/router. ...
  2. Make sure that the power cord is plugged in.
  3. Turn on the machine and wait until the machine is in the Ready state.
  4. Hold down the WPS or AOSS™ button on your WLAN access point/router for a few seconds.
  5. https://www.youtube.com/watch?v=7kE9Sn3V8rI
Brother Office... | Answered on Jun 22, 2020
If you are incapable to print to your installed Brother printer because it is looking as offline, then you can change some of the printer's settings so that you can resume printing documents. Windows gives a built-in feature for toggling between offline mode, which can resolve many of the "Printer Offline" notifications that you are receiving from your Brother printer. But, if this option does not solve your problems, you may need to make some real differences to your printer connection to replace normal printing functionality.
Steps that fix Brother Printer Offline Windows 10:
1. Click the "Start" button at the bottom-left corner of your computer screen, and then click "Devices and Printers."
2. Right-click your Brother printer icon, and then click "See What's Printing."
3. Click "Printer" at the top of the window, and then look for a blue checkmark to the left of "Use Printer Offline."
4. Full Solution of error is here- Brother Printer Offline Windows 10
If Brother Printer Offline Windows 10 is not resolved, this might mean there's waste within the printer's inside. Call the customer services our check this Blog for a full solution.
Brother Office... | Answered on Jun 16, 2020
If the error message or code on your malfunctioning Brother printer is beyond your grasp, we suggest trying a simple fix, if applicable: ... Double-click on Services > scroll down to Print Spooler > right-click Print Spooler > restart. Double-click on Print Spooler > select Automatic for 'startup type' > apply > click Ok.Aug 8, 2017
DIY guide for fixing Brother Printer errors ' Global Office ...
Brother Office... | Answered on Jun 10, 2020
Here is a Brother support page which includes a video on clear paper jams for this and related printers. It is the video near the bottom of the page.
https://www.brother-usa.com/support/hl5470dw
Need more help? Talk to me directly.
http://6ya.com/repairsolutions
Make sure all previous printer software and drivers are removed before installing new printer.
Brother Office... | Answered on Jun 04, 2020
https://support.brother.ca/app/answers/detail/a_id/136366/~/how-do-i-clear-the-message-replace-pf-kit-1%3F
To do this, press the GO and + buttons at the same time until "Reset Parts Life" is displayed. Now press the + button until PF Kit 1 or 2 is displayed and press SET. The counter will now be reset.
https://support.brother.com/g/s/id/pdf_pub/faq/faq00000141/pfkit_hl6050.pdf
Brother Office... | Answered on May 31, 2020
Have you looked at the following site, which a a video on the wireless setup?
https://support.brother.com/g/b/faqend.aspx?c=eu_ot&lang=en&prod=mfcl2700dw_us_eu_as&faqid=faq00100429_000
Brother Office... | Answered on May 29, 2020
If the printer status is Offline
Right-click the icon for your Brother machine > See what's printing > Printer > Use Printer Offline (remove the checkmark). If Use Printer Offline is greyed out, click Open As Administrator. Enter your administrator password, and then click Yes
Brother Office... | Answered on May 28, 2020
Check that Your printer is properly connected and there is ink in cartridge. Also Check for the paper jam. If every think fine and still its showing same error message read blog Printer in error state.
Brother Office... | Answered on May 27, 2020
POSSIBLY REPLACEMENT CHECK WITH MANUFACTURER
Brother Office... | Answered on May 23, 2020
How do fix the issue Brother's printer not Responding to Mac:
  1. Click the apple menu icon, Click printer & scanners.
  2. Right click the control click the list for the available devices.
  3. Click on resetting printing system, click reset button to ensure printer is reset.
https://www.easyprintersupport.com/brother-printer-not-working-with-mac/
Brother Office... | Answered on May 22, 2020
To set up your Brother machine on a wireless network:
  1. Connect the power cord to your Brother machine and then connect it to an electrical socket. ...
  2. Press the Up or Down arrow key to select the Network option and press OK.
  3. Press the Up or Down arrow key to select the WLAN option and press OK.
https://support.brother.com/g/b/faqend.aspx?c=us&lang=en&prod=hll2360dw_us&faqid=faq00100429_003
https://www.youtube.com/watch?v=kMAqUwnvADE
Brother LC51BK Print cartridge, Inkjet Print Technology, Black and Color Print Color, Duty Cycle, 400 Page Color, 500 Page Black, For use DCP130C, MFC240C, MFC440CN, MFC665CW, MFC845CW, MFC2480C, MFC3360C, MFC5460CN, MFC5860CN Fax Machines, FAX1360, FAX1860, Logo
2 questions posted
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
View Most Popular
  • Brother Office Equipment & Supplies
Most Popular Question
brother printer error unable clean 50
  • Office Equipment & Supplies
