20 Most Recent Tissot Le Locle T41.1.423.33 Watch for Men Questions & Answers
Do as follows:
1) At any time of the day pull the crown out and advance watch hands forward for EXACTLY 12 hours ( for example: if it's 6.35 on your watch, then after advancing hands it will be 6.35 again, just minute hand will be forwarded clockwise 12 full circles, while hour hand will be forwarded 1 full circle). Push the crown back in.
2) Pull the crown out to the date setting position and change to the desired date. Pull the crown back in.
Now your watch will be changing dates at midnight continuosly.
Rate me, please.
Tissot Le Locle... | Answered on Apr 04, 2009
Try Googling (tissot)(T670)(manual) without parens for instructions.
Tissot Watches | Answered on Nov 09, 2019
Hi.
Can I assume this is a quartz powered watch? If so, sometimes, if thger bettery is either old or has started leaking hen is causes misfires in the time regulator.. First step would be chasnge battery & resdet the watch & monitor it. If this does not work, then put it into a Tissot service centre. Ifts not a quartz movement, there is no fault in a mechanical movement really that could cause this.
Hope this helps.
Tissot Watches | Answered on Oct 06, 2019
Take your Tissot to a jeweler who will open it, identify the battery type, and perhaps install a new one.
Tissot Watches | Answered on Jun 15, 2019
From your description it could be the main spring is broken, or there is a gear and or bushing failure. You will have to give the watch to a place that can service your watch. If you contact Tossot customer support they can advise you.
Tissot Watches | Answered on Apr 29, 2019
Take your Tissot two timer to a jeweler for battery identification.
Tissot Watches | Answered on Nov 13, 2018
A water resistant watch usually has a back that screws into the case and seals with a rubber O ring.
Sometimes the back can be very tight to unscrew so even with the dedicated wrench it is difficult to remove without damage to the case. The professional would disconnect one end of the bracelet and clamp the case into a special holder.
Once a non-dealer has replaced the battery it is usual to discover the back isn't replaced as tightly as original - this is reflected by the usual warning the watch will no longer be waterproof. The only way to retain the waterproof or water resistant quality is to have the battery replaced by a dealer or manufacturer when it will be, if required, pressure tested.
Tissot Watches | Answered on Nov 05, 2018
Take your Tissot to a jeweler for battery identification and replacement.
Tissot Le Locle T41.1.423.33 Watch for Men Logo
Popular Tags
4 questions posted
Top Tissot Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Anonymous
Level 1 Expert
Are you a Tissot Watch Expert? Answer questions, earn points and help others
View Most Popular
Tissot Watches
  • Tissot Watches
Most Popular Question
date function notworking properly
  • Watches
