20 Most Recent Tissot T Classic Seastar II T55.8.283.11 Automatic Watch Questions & Answers
the problem is the air spring on the balance wheel it can be 1 or 2 things wrong spring stuck together with oil spring got crossed or if it's been neat a magnet, needs jeweler repair shop
Tissot T Classic... | Answered on Mar 15, 2013
A self winding watch will run for 2-3 days if it is not worn (they thrive on being used) and it sounds as if you have not been using it; is this the case?
It could be that the winder does not operate on the spring (some watches don't), so to wind it up you need to activate the self winding mechanism.
You can do this by gently swinging the watch from side to side for a few minutes. This will simulate the normal operation when it is being worn.
If you continue to have trouble with it stopping, it could be that it needs cleaning. I had a similar problem with a watch I had some years ago.
Tissot T Classic... | Answered on Jan 18, 2011
Are you sure it winds? They also make battery operated watches! :-)
Tissot T Classic... | Answered on Jan 15, 2010
I think that's a SR936Sw or equivalent. That watch has a pop-off back, so its easy enough to access. You'll need a jewelers pincers or something like a sharp pin to extract the battery (Carefully!) as its embedded in the body.
Tissot T Watches | Answered on Apr 09, 2016
If your watch is battery operated, the most common reason is battery itself. Don't mind it was bought in January, because watch itself could be in shop storage for years (even if it is one of the new models).
If your watch is automatic/hand wound, then there might be a problem with movement and in this case you will need help of qualified watchmaker.
Tissot T Watches | Answered on Aug 26, 2014
Tissot T Classic Seastar II T55.8.283.11 Automatic Watch Logo
Popular Tags
9 questions posted
Top Tissot Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Anonymous
Level 1 Expert
Are you a Tissot Watch Expert? Answer questions, earn points and help others
View Most Popular
T Tissot
  • T Tissot
Most Popular Question
not regulate tissot visodate seastar
  • Watches
