20 Most Recent Zephyr Pyramid ZPY-E30 Kitchen Hood Questions & Answers
0answers
0answers
Almost impossible to mount...difficult access to
I presume you are mounting the hood under an exsisting cupboard. Are you trying to screw the mounting screws in with the rangehood in position? If this is the case you need to screw the four mounting screws in first nearly all the way, then position the hood over the larger part of the "keyhole" and push back. Then tighten screws up and also if you can put another screw in somewhere to make sure it won`t move, even if you have to drill another hole. I know from experience that in some hoods the screws are hard to get to, a long screwdriver bit can help or a screwdriver that can have an adjustable angle is useful sometimes too. Hope this helps.
1/21/2011 7:37:22 PM • Zephyr Pyramid... • Answered on Jan 21, 2011
How do i wire
how do I WIRE trapeze ctp-e54sx and make balance air circulation
1/18/2011 4:05:30 PM • Zephyr Pyramid... • Answered on Jan 18, 2011
I need a replacement bulb Zephyr Pyramid range
According to the "Use, Care and Installation Guide for your unit,
Replacement bulbs are available at
specialty lighting stores. Purchase type
JDR E27 50W halogen bulbs.
Or to order bulbs, please call our service
center: 888-880-8368 or online parts store:
www.zephyronline.com
7/30/2009 3:29:13 PM • Zephyr Pyramid... • Answered on Jul 30, 2009
Removing existing light bulb to replace.Flush
Use rubber kitchen glove to grasp bulb. Be careful not to cut yourself if bulb breaks.
7/7/2009 10:10:09 PM • Zephyr Pyramid... • Answered on Jul 07, 2009
Can find the halogen replacement bulb for my pyramid zephir
You can purchase directly from Zephyr through their website, www.zephyronline.com
2/10/2009 11:40:37 PM • Zephyr Pyramid... • Answered on Feb 10, 2009
Noisy fan
MOTOR HOUSING IS CRACKED MADE OF PLASTIC
3/31/2008 5:26:11 AM • Zephyr Pyramid... • Answered on Mar 31, 2008
My Zephyr hood just turned on and off by itself.
Probably a bad switch...... or ghosts!
1/24/2022 6:37:15 PM • Zephyr Kitchen... • Answered on Jan 24, 2022
I have a Zephyr Hood that the lights do not turn off and the fan will come on randomly. What can I do to fix this?
Contact the maker. That should be covered under a recall or under warranty. Appliances shouldn't start on their own! https://zephyronline.com/ ..
9/5/2021 3:05:40 PM • Zephyr Kitchen... • Answered on Sep 05, 2021
I have a Zephyr range hood with GU10 bulbs. Easy to remove , unable to re-install. I'm the 3rd person on this journey.
The two small pins on the bottom of the bulb must line up with the small holes in the base of the socket. This can be tricky since you can't see it once the bulb is inserted. Make sure their nothing already in one of the socket pin holes (like part of the old bulb) and the note the socket hole locations and (lightly, using your finger tips) fit the bulb up into the socket and wiggle it until the pins and holes align. It does fit, but sometimes it is not without a challenge.
10/4/2020 7:51:32 PM • Zephyr Kitchen... • Answered on Oct 04, 2020
Our zephyr vent hood fan turns itself on, about two or three times a week. Often late at night, waking us up. What can we do to fix this?
I am completely guessing but assume it uses electronic switching? A standard or old sort of cooker hood use mechanical switches, which would have to be seriously faulty to switch themselves on, though water ingress from condensation entering a switch can over time cause a carbonised track to form that could when damp carry enough current to run a low powered motor or alternatively blow the fuse/trip the RCD if the track is a ground path. With electronic switching there are usually buttons mounted on a circuit board and in order to produce compact dimensions the tracks are very close together. The buttons usually need only make a momentary contact for a very small current to flow and the brain to switch on the motor. A tiny drop of water entering this unit can cause mayhem...
6/11/2020 1:45:03 AM • Zephyr Kitchen... • Answered on Jun 11, 2020
Okeanito grease
I would try a hand steamer, it definitely won't affect the stainless and I'm assuming you have a large glass, stainless or tile cplashback. Hope this helps
10/21/2019 6:18:59 AM • Zephyr Kitchen... • Answered on Oct 21, 2019
Why can't I find anyone to service my out of warranty Zephyr ventilation hood?
I would suggest taking the see item number did you have email the company or call them as to how to solve the problem if you're already not done so Ice Cube what can be done also try to find another ventilation Hood it is about the same size
5/17/2019 8:14:02 PM • Zephyr Kitchen... • Answered on May 17, 2019
Zephyr Pyramid ZPY-E30 Kitchen Hood Logo
Popular Tags
13 questions posted
Top Zephyr Kitchen Ranges Experts
Dale Copeland
Dale Copeland
john h
Are you a Zephyr Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Zephyr Kitchen Ranges
Most Popular Question
need replacement bulb zephyr pyramid
  • Kitchen Ranges
