20 Most Recent Zephyr Tornado II AK8200S Kitchen Hood Questions & Answers
Zephyr Tornado ll--only a month
This "F" symbol will always flashes after 30 hours of use and not 30 days.This is a remainder for you to clean the filter.SO your Zephyr Tornado can work more perfectly
When it flashes "F" clean it and you have to tell the Zephyr Tornado that the filter is
cleaned so it will stop flashing the remainder "F".For this you have Reset the filter clean reminder timer.Please check that the filter is re-installed (with hood off).
Press and hold (-) button for approximately 5 seconds until "F" display disappears.The
timer is reset and it will wake up after 30 hours of use.
Note:Still problem persist check you have reinstalled the filter properly with hood off).
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
9/11/2010 4:58:54 PM • Zephyr Tornado... • Answered on Sep 11, 2010
I have a Zephyr Hood that the lights do not turn off and the fan will come on randomly. What can I do to fix this?
Contact the maker. That should be covered under a recall or under warranty. Appliances shouldn't start on their own! https://zephyronline.com/ ..
9/5/2021 3:05:40 PM • Zephyr Kitchen... • Answered on Sep 05, 2021
I have a Zephyr range hood with GU10 bulbs. Easy to remove , unable to re-install. I'm the 3rd person on this journey.
The two small pins on the bottom of the bulb must line up with the small holes in the base of the socket. This can be tricky since you can't see it once the bulb is inserted. Make sure their nothing already in one of the socket pin holes (like part of the old bulb) and the note the socket hole locations and (lightly, using your finger tips) fit the bulb up into the socket and wiggle it until the pins and holes align. It does fit, but sometimes it is not without a challenge.
10/4/2020 7:51:32 PM • Zephyr Kitchen... • Answered on Oct 04, 2020
Our zephyr vent hood fan turns itself on, about two or three times a week. Often late at night, waking us up. What can we do to fix this?
I am completely guessing but assume it uses electronic switching? A standard or old sort of cooker hood use mechanical switches, which would have to be seriously faulty to switch themselves on, though water ingress from condensation entering a switch can over time cause a carbonised track to form that could when damp carry enough current to run a low powered motor or alternatively blow the fuse/trip the RCD if the track is a ground path. With electronic switching there are usually buttons mounted on a circuit board and in order to produce compact dimensions the tracks are very close together. The buttons usually need only make a momentary contact for a very small current to flow and the brain to switch on the motor. A tiny drop of water entering this unit can cause mayhem...
6/11/2020 1:45:03 AM • Zephyr Kitchen... • Answered on Jun 11, 2020
Okeanito grease
I would try a hand steamer, it definitely won't affect the stainless and I'm assuming you have a large glass, stainless or tile cplashback. Hope this helps
10/21/2019 6:18:59 AM • Zephyr Kitchen... • Answered on Oct 21, 2019
Why can't I find anyone to service my out of warranty Zephyr ventilation hood?
I would suggest taking the see item number did you have email the company or call them as to how to solve the problem if you're already not done so Ice Cube what can be done also try to find another ventilation Hood it is about the same size
5/17/2019 8:14:02 PM • Zephyr Kitchen... • Answered on May 17, 2019
Light bulb keeps falling out of the zephyr range hood, what are we doing wrong?
not screwing it in tight not twisting is bayonet type or if fluro tube not rotating the tube 1/4 turn after instakking
9/22/2018 2:56:52 AM • Zephyr Kitchen... • Answered on Sep 22, 2018
I need to replace part #11000006 (on off switch) on my zephyr ZPY-E36S. Do you have one? Can mine be repaired (burnt out switch wires)?
-If only the wire itself burn then just replace the wire. You'll be okay. But if the switch it self totally burn, all the plastic around already melt down then yes it need to be replace. -If you totally can't get the original one to replace, you can buy one from Lowes and modify to hole to accept it. It'll be okay as well. Good luck Mai
1/16/2018 8:32:23 PM • Zephyr Kitchen... • Answered on Jan 16, 2018
Zephyr Tornado II AK8200S Kitchen Hood Logo
4 questions posted
Top Zephyr Kitchen Ranges Experts
Vish Iyer
Vish Iyer
Dale Copeland
Dale Copeland
Are you a Zephyr Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Zephyr Kitchen Ranges
Most Popular Question
zephyr tornado ll only month
  • Kitchen Ranges
