20 Most Recent Zephyr Cyclone AK6500 Kitchen Hood Questions & Answers
It sounds like there is a restriction in the vent or the hood is to low. It should be at least 18" above the cooking surface.
Zephyr Cyclone... | Answered on Jun 24, 2010
Yes, it is possible to replace the light bulbs without removing the panel that surrounds the two bulbs. The problem is that those bulbs get slippery because of cooking oil splatters.
I recommend that you use a paper towel and some window cleaner (aka: Windex) Spray the towel and clean the bulb. Let each dry and turn the bulb to loosen it out. Use the moist paper towel to help turn is needed. Be so careful to not break the bulb as you remove it. Good Luck!
Zephyr Cyclone... | Answered on May 21, 2010
I am completely guessing but assume it uses electronic switching?
A standard or old sort of cooker hood use mechanical switches, which would have to be seriously faulty to switch themselves on, though water ingress from condensation entering a switch can over time cause a carbonised track to form that could when damp carry enough current to run a low powered motor or alternatively blow the fuse/trip the RCD if the track is a ground path.
With electronic switching there are usually buttons mounted on a circuit board and in order to produce compact dimensions the tracks are very close together. The buttons usually need only make a momentary contact for a very small current to flow and the brain to switch on the motor.
A tiny drop of water entering this unit can cause mayhem...
Zephyr Kitchen... | Answered on Jun 11, 2020
I would try a hand steamer, it definitely won't affect the stainless and I'm assuming you have a large glass, stainless or tile cplashback. Hope this helps
Zephyr Kitchen... | Answered on Oct 21, 2019
I would suggest taking the see item number did you have email the company or call them as to how to solve the problem if you're already not done so Ice Cube what can be done also try to find another ventilation Hood it is about the same size
Zephyr Kitchen... | Answered on May 17, 2019
not screwing it in tight
not twisting is bayonet type or if fluro tube not rotating the tube 1/4 turn after instakking
Zephyr Kitchen... | Answered on Sep 22, 2018
-If only the wire itself burn then just replace the wire. You'll be okay. But if the switch it self totally burn, all the plastic around already melt down then yes it need to be replace.
-If you totally can't get the original one to replace, you can buy one from Lowes and modify to hole to accept it. It'll be okay as well.
Good luck
Mai
Zephyr Kitchen... | Answered on Jan 16, 2018
clean the fat and gunk build up off the fan blades
Zephyr Kitchen... | Answered on Dec 19, 2017
Zephyr Cyclone AK6500 Kitchen Hood Logo
8 questions posted
Top Zephyr Kitchen Ranges Experts
Marvin
Marvin
Vernon Taylor
ray gallant
Are you a Zephyr Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Zephyr Kitchen Ranges
Most Popular Question
dripping kitchen exhaust fans
  • Kitchen Ranges
