20 Most Recent Aastra Telecom Aastra 9417CW Two-Line Telephone with Call Waiting Caller ID Questions & Answers
This Depends on your providers system . If yo go and retrieve your messages and hit 4 3 2 2 this will get you to nowhere you can record a message for incoming calls. If you want to change you message for when some calls you and you are on the phone you would do the same as above but hit 4 3 2 1. That is where you change your "on the phone message" never put a date in that one. Just record " hi I am on the phone at the moment please lease a message at the tone" Hope this helps
Aastra Telecom... | Answered on Nov 06, 2013
Scroll through all Callers, one of them is stuck as "new",
Aastra Telecom... | Answered on Apr 03, 2013
I believe the problem is even with the ringer off, if you are on one line the other line will ring which is annoying if you are on the phone. I have yet to figure out how to prevent that but would be glad to post an answer when and if I find one.
Aastra Telecom... | Answered on Nov 15, 2012
With my Moto-G I press the volume button then tap the top icon till it shows a bell. Pressing both buttons together can also toggle sound on/off.
Lands Phones | Answered on Oct 21, 2020
https://www.brisbanepropertyvaluations.com.au/
Lands Phones | Answered on Oct 02, 2020
Here's some suggestions from the Vtech site:
If the battery(s) has been in service for more than one year....
As a rechargeable battery gets older, its ability to hold a charge decreases. If your battery has been in service for more than twelve months, it may be a good idea to replace it.
If you are replacing the battery and you need assistance, visit our Battery Finder link. If a battery for your model is unavailable, you can search the Internet using the key words cordless phone batteries for an on-line supplier. If you prefer to purchase locally, you can look for a replacement battery at your area consumer electronics retailers. It is recommended that you take your present battery with you to insure your replacement is the correct size and has the correct plug (where applicable) and specifications (for example - 3.6v 400mAh Ni-Cd). Caution when replacing batteries
If your model takes individual cells, do not use non-rechargeable batteries. Use only the recommended rechargeable batteries as prescribed in your User's Manual.
If the battery(s) has been in service for less than one year....
If the handset shows any sign of life (any lights; characters on the display screen; sounds when keys are pressed), your handset is not dead, making it unlikely that a new battery will fix the problem. Consider the following:
Is the base unit getting power?
If your base unit is not getting power, your handset is not charging. Tip: Do not plug your Base Power Adaptor into an electrical outlet controlled by a switch (for example, a light switch on the wall or a power strip with an On/Off switch).
If your battery pack is the plug-in type, is it securely plugged into the handset?
Disconnect, and then reconnect the battery plug to ensure a good connection. In addition, make sure the battery cover is on securely.
Do you see any charge indicators on the base or handset?
Depending on your model, the handset and/or base will have indicators to let you know when the battery is charging. Check your User's Manual for details.
Remember, if the handset shows any sign of life (any lights; characters on the display screen; sounds when keys are pressed), then is not dead, making it unlikely that a new battery will fix the problem. Try the following reset procedure:
Reset your Phone
If your telephone is not operating normally, disconnect the battery(s) from the handset and disconnect power from the base. After a few minutes, connect power to the base, install the battery(s) and cradle the handset in the base to allow it to establish a link. You can now try using your phone again.
Lands Phones | Answered on Sep 08, 2020
I might be broken then and has stopped working
Lands Phones | Answered on Sep 03, 2020
Aastra Telecom Aastra 9417CW Two-Line Telephone with Call Waiting Caller ID Logo
Popular Tags
9 questions posted
Top Aastra Telecom Lands Phones Experts
Marvin
Marvin
k24674
Are you an Aastra Telecom Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Aastra Telecom Lands Phones
Most Popular Question
aastra voicemail
  • Lands Phones
