20 Most Recent Swiss Legend Commander Chronograph Blue Rubber 30011 33 Watch for Men Questions & Answers
Sorry we have no parts services here.
Swiss Legend... | Answered on Jan 11, 2018
If the day will not change when you pull the crown out to the first position (try both directions) then pull the crown out to the second position. Advance the hands until yesterday shows in the day window. Now set the date by putting the crown in the first position and set it to yesterdays date. Now advance the hands (position 2 until the date and day change and then set the time. Done
Swiss Legend... | Answered on Mar 15, 2015
1 Nonstandard Battery required
Swiss Legend... | Answered on Apr 23, 2019
Take your Swiss Legend watch to a jeweler for identification of battery type and possible installation of a new one.
Swiss Legend... | Answered on Mar 28, 2018
The links are removed by a variety of methods. Look at the side of the link, is there a small pin? if so there will be an arrow on the back of the link. this is the direction to push the pin out. there also may be a flat pin in the end on the back of the link you will see a little round hole covering half the pin this will need a jeweller to remove.
Swiss Legend... | Answered on Jan 09, 2018
Common solution, locally.... :)
Swiss Legend... | Answered on Nov 04, 2017
Hi Leigh.
The battery supplies voltage to a precise timing circuit to generate brief pulses of low voltage electricity to a magnetic coil which swings a weighted cam (wheel) to keep everything in motion.
This cam or some other mechanical part may have become dislodged or misaligned, causing drag.
In a nutshell, a watchmaker will need to inspect it for wear.
Could be a jewel-bearing has fallen out.
Does this help?
Regards,
Clive.
SORRY but FIXYA can not tell as we can not see the battery numbers
Swiss Legend... | Answered on Sep 13, 2017
Sorry...
New or not SWISS use the second hand as an early indicator of the battery state.
My memory is that it starts by skipping seconds...
Then the second hand stops...
Then the watch...
ELSE
The movement is bad.
If it is INDEED NEW... Take it back & get
yourself a fresh one.
Carnac the Magnificent
Swiss Legend... | Answered on Mar 26, 2017
Swiss Legend Commander Chronograph Blue Rubber 30011 33 Watch for Men Logo
7 questions posted
Top Swiss Legend Watches Experts
Janelle Schoonover
Janelle Schoonover
Clive
Clive
Tom Chichester
Are you a Swiss Legend Watch Expert? Answer questions, earn points and help others
View Most Popular
  • Swiss Legend Watches
Most Popular Question
find replacement rubber band commander
  • Watches
