20 Most Recent Swiss Legend Automatic Stainless Steel with Winder Watch for Men Questions & Answers
ur watch cells must be discharged
Swiss Legend... | Answered on Jan 02, 2011
You are wanting to know battery type, not number. Take your Swiss Legend watch to a jeweler who will show you the correct way to open it and replace the battery.
Swiss Legend... | Answered on Nov 11, 2020
1 Nonstandard Battery required
Swiss Legend... | Answered on Apr 23, 2019
The links are removed by a variety of methods. Look at the side of the link, is there a small pin? if so there will be an arrow on the back of the link. this is the direction to push the pin out. there also may be a flat pin in the end on the back of the link you will see a little round hole covering half the pin this will need a jeweller to remove.
Swiss Legend... | Answered on Jan 09, 2018
Common solution, locally.... :)
Swiss Legend... | Answered on Nov 04, 2017
Hi Leigh.
The battery supplies voltage to a precise timing circuit to generate brief pulses of low voltage electricity to a magnetic coil which swings a weighted cam (wheel) to keep everything in motion.
This cam or some other mechanical part may have become dislodged or misaligned, causing drag.
In a nutshell, a watchmaker will need to inspect it for wear.
Could be a jewel-bearing has fallen out.
Does this help?
Regards,
Clive.
Sorry...
New or not SWISS use the second hand as an early indicator of the battery state.
My memory is that it starts by skipping seconds...
Then the second hand stops...
Then the watch...
ELSE
The movement is bad.
If it is INDEED NEW... Take it back & get
yourself a fresh one.
Carnac the Magnificent
Swiss Legend... | Answered on Mar 26, 2017
Swiss Legend Automatic Stainless Steel with Winder Watch for Men Logo
3 questions posted
Top Swiss Legend Watches Experts
Lisa Christine
Lisa Christine
Tom Chichester
Wasted space
Are you a Swiss Legend Watch Expert? Answer questions, earn points and help others
View Most Popular
  • Swiss Legend Watches
Most Popular Question
automatic watch stopped ticking watch
  • Watches
