20 Most Recent Toro Power Clear 621 ZE 21 163cc Single Stage Snow Blower E-Start Questions & Answers
there is usally a bolt underneath the motor which you take out it is usally 1/2 in use a socket to take it out drain put back on refill some are on the topside at the bottom but you get the idea
Toro Power Clear... | Answered on Jan 20, 2015
plug in Electric start. Push Choke to 'ON'. press Primer Bulb about 2 times. Turn Key to 'ON' Press Starter.
If you didn't run it completely dry of Gas last season I bet the Ethanol gas messed up your carburetor
Toro Power Clear... | Answered on Dec 23, 2014
usually not the float. there is a needle attached to the float that slides up a small hole and against a rubber seat. the seat over time becomes sticky and sticks the needle up and in place blocking the main fuel entrance. you can pick up a rebuild kit from you local small engine shop. you will need the 5 digit model number located on a sticker by the wheel axle....
Toro Power Clear... | Answered on Feb 08, 2013
https://www.justanswer.com/small-engine/97k4d-toro-lx-427-won-t-start.html
Toro Garden | Answered on Jan 31, 2020
if it has a twin cylinder engine, make sure both cylinders are firing.
Toro Garden | Answered on Dec 27, 2019
it needs fuel.
Toro Garden | Answered on Dec 04, 2019
Typical snow blower shifts by moving a drive wheel on a hexoganal shaped shaft. Likely the wheel has rusted to the shaft from insufficient maintenance.
Remove the rear/bottom cover plate to access the transmission (usually 4 bolts). Lubricate shaft/wheel with penetrating oil and work free.
Avoid getting oil on the drive wheel and disc or thoroughly clean the disc and wheel with a liberal application of alchohol until wiping with a rag comes clean.
Lubricate any drive chains as well.
Toro Garden | Answered on Dec 02, 2019
Hi Jacquelin-
I found this link.
https://www.manualslib.com/manual/772531/Toro-38588.html?page=16#manual
On page 15-16, it talks about the "Replacing the Drive Belt". This might be the problem.
Hope this helps.
Toro Garden | Answered on Nov 27, 2019
If you didnt treat fuel before storage last season then likely the carburetor is fouled. Try adding a fuel treatment e.g. Seafoam, but likely ithe carb will need a thorough cleaning or replacement.
Toro Garden | Answered on Oct 29, 2019
Let warm up if still does need new spark plug
Toro Garden | Answered on Oct 27, 2019
Try a short burst of starter fluid into the carburetor and promptly pull starter. If it runs for a couple seconds and quits then the carburetor is not delivering fuel.
If it doesnt run on starter fluid then either flooded, insufficient spark, or poor compression / crankcase leak.
I have had the same issue with Toro. Finally took it to a local wizard. AFter about 5 minutes if him trying he suggested it would make a great boat anchor. Once Toro goes out of factory specs, that's just about it. A few lucky folks I know with Toro products either accidentally stumble on the just-right combinations or off to the lake they go.
Toro Garden | Answered on Sep 29, 2019
Check and see if there is a shear or safety pin in one of the drive pulleys that has broken.See if there is a pulley that turns by hand when this happens. Could be one has broken but grabs for a little bit. Also check the drive belt and see if it is slipping Check all the drive areas . BE SAFE BY TAKING THE KEY OUT AND TRYING BY HAND>
Toro Garden | Answered on Sep 23, 2019
Toro Power Clear 621 ZE 21 163cc Single Stage Snow Blower E-Start Logo
3 questions posted
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
roeb
Marvin
Marvin
Are you a Toro Garden Expert? Answer questions, earn points and help others
View Most Popular
Toro Garden
  • Toro Garden
Most Popular Question
procedure start single stage electic
  • Garden
