20 Most Recent Bazooka BTA10100 Car Subwoofer Questions & Answers
6answers
Intermittent Problem
One thing that comes to mind is you said the heatsink had come loose. if this was the case and it was the heatsink for the output transistors. Then this seems to be the best place to look for a broken solder joint. When either the unit heats up or vibration. One of the legs to one of the transisters opens this would case a half wave cycle drop. Do not know if I would consider the sound it would make as static. But it would become very garbled. get a bright light a slowly look over the circuit for broken solder joints use a magnifier if you have one. also wiggle the wires and tap on the circuit with something non-conductive like wood or plactic see if you can make this cause the condition. This may help narrow your search. Check as well on the top of the circuit look close at the transistor leads, because flexing back and forth can case them to break if flexed in the right place.
7/13/2008 11:53:56 AM • Bazooka BTA10100... • Answered on Jul 13, 2008
3answers
2001 ford explorer sport trax
probably exposed wires are touching something or they werent spliced very good,id check every point wher the wires were spliced together
3/30/2008 5:25:30 AM • Bazooka BTA10100... • Answered on Mar 30, 2008
0answers
Bt8250d is cutting out
Loose connection or your power cable and earth cable to your amp are not a heavy enough gauge.
11/30/2014 4:34:44 PM • Bazooka Car... • Answered on Nov 30, 2014
0answers
0answers
0answers
Speaker Fried, is my Amp toast too?
You are sending TOO much power to the speakers, Replace the speakers and then get a much smaller amp that is within the ratings of the speakers. ACTUALLY you should get an amp that is aboout 1/2 the total rating of the speakers.
You should ALSO procure a sound meter to verify the sound level is within safe limits. If you insist upon abusing your ears with too high a sound pressure, be ready to buy hearing aids at a VERY young age.
You also need to know that the enclosure of the speaker plays a part in keeping the speaker from tearing itself to pieces.
MANY of the auto sound system installers are hacks that don't do it right and you see what happens to your expensive equipment!
Using even a Radio Shack sound meter properly will protect your preciuos hearing for later life.
12/22/2009 9:19:21 PM • Bazooka Car... • Answered on Dec 22, 2009
Bazooka amp
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, do the following. I'll assume that you've checked the amplifier's on-board fuses.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it remains in protect mode, the amp almost certainly has shorted output transistors and will need to be repaired.
6/15/2008 6:52:48 PM • Bazooka Car... • Answered on Jun 15, 2008
2answers
Iwant money for bussines
try getting a job
6/16/2024 9:16:20 PM • Car Audio &... • Answered on Jun 16, 2024
Sir, my DPX U5120 bottons are not working. What's the solution?
Sterio button and knob not working
6/16/2024 11:56:52 AM • Car Audio &... • Answered on Jun 16, 2024
My girlfriend got a DVDstuck she put it in upside down the wrong way and we're having trouble getting the DVD out player stuck in a performance technique icbm-9529 DVD player and how do we get it out
  • Turn off the DVD player and unplug it from the power source. Wait for a few minutes to ensure the player is fully powered down. Plug the DVD player back in and turn it on. Sometimes, the reset process can cause the player to eject the disc.
  • Locate the manual eject hole on the front of the DVD player. It is usually a small pinhole. Insert a paperclip (straightened) or a similar thin, stiff object into the hole. Press gently but firmly. This should manually trigger the eject mechanism and release the DVD tray.
  • Turn off and unplug the DVD player. Hold the DVD player upside down and gently shake or tap the player while pressing the eject button. Be cautious to avoid dropping the player or applying too much force.
  • Turn off and unplug the DVD player. Carefully remove the screws on the outer casing of the DVD player. Gently lift the casing off to expose the DVD drive. Locate the DVD tray mechanism and manually slide the tray out to retrieve the stuck DVD. Be careful not to touch any internal components unnecessarily to avoid damage
  • if the above methods do not work, or if you are uncomfortable opening the DVD player yourself, it is advisable to seek professional help from a technician to avoid causing further damage to the DVD player.
5/31/2024 7:01:18 AM • Car Audio &... • Answered on May 31, 2024
Scosche gm21sr
Need wiring diagram for 2012 Chevy Impala
5/27/2024 6:23:44 PM • Car Audio &... • Answered on May 27, 2024
HDD is not available shown in AVIC-HRZ99 How it fix?
https://www.minidisc.wiki/equipment/pioneer/auto/avic-hrz99
5/25/2024 10:44:06 AM • Car Audio &... • Answered on May 25, 2024
I bought this pionner dvd model no.avic f 9880 dab but it was password how do i reset or remove it from being password protected
I would contact Pioneer. After proving ownership, they should be able to help. https://www.pioneer-car.eu/eur/support/contactform
5/21/2024 7:05:35 AM • Car Audio &... • Answered on May 21, 2024
How can I free down Elipse AVN1106D CD driver software?
it is not a computer but is CAR sound systems. the answer is ask the maker for support. read post 10 https://www.pakwheels.com/forums/t/eclipse-avn1106d-map-disc-required/226389
5/17/2024 12:20:07 PM • Car Audio &... • Answered on May 17, 2024
2004 Lincoln Navigator (Canada) 6-cd changer stereo died. I want to get an after-market stereo but not sure what else I need? Which wire harness I need, connector, adaptor or installation kit?
Like for like. Go to a breakers yard. The audio system is an extension of the Body Control Module, part of the computer system and is used to Audio Alerts, Chimes etc. that play through the speakers. If you replace it with a completely different unit, the BCM won't understand the data. A company like Crutchfield will guide on you what _might_ work, and they will also supply harness connectors. It needs to be specific. https://www.google.com/search?q=2004+Lincoln+Navigator+(Canada)+6-cd+changer+stereo ..
5/12/2024 12:31:47 AM • Car Audio &... • Answered on May 12, 2024
How to set time and alarm in KADIO KD-3810N
Insert Batteries: First, insert 2 AA batteries into the back of the clock. Access Time Setting Mode: Press and hold the Mode button for 5-10 seconds until the clock enters the setting mode. Adjust Time: Once in the setting mode, use the Up and Down buttons to change the time, month, and date. Press the Mode button to cycle through the different settings. Set Hour and Minute: When you reach the time setting, adjust the hour and minute using the Up and Down buttons. Press the Mode button again to move to the next setting (e.g., month, date). Exit Setting Mode: After setting the time, press the Mode button to exit the setting mode.
5/10/2024 4:28:29 PM • Car Audio &... • Answered on May 10, 2024
Bazooka BTA10100 Car Subwoofer Logo
3 questions posted
Top Bazooka Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Bazooka Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Bazooka Car Audio & Video
Most Popular Question
12 kicker square rubber broken
  • Car Audio & Video
