20 Most Recent
Verbatim USB 3.0 Universal Card Reader - 97706 Black USB 3.0 Questions & Answers
Computer is not seeing verbatim usb 3.0 card reader
Try a different usb port on your computer. If you using ones on the front, try the ones in the back. If that doesn't work, try the reader on a different computer. If the reader doesn't work it is most likely defective. A pretty common occurance with usb card readers in general.
Also try putting a card in the card reader before inserting it into the computer, not while it is plugged in.
Good luck
About License under software manager
use linux mint 21.3 Cinnamon Edition. I see in the software manager under licence, where it say changing is not allowed. what is the meaning of it? Please tell me. (Everyone is permitted to copy and distribute verbatim copies of this license document, but changing it is not allowed.)
4/19/2024 3:12:17 PM •
Verbatim...
Answered
on Apr 19, 2024
My Verbatim External hard drive Model 47672 just won't power up all of a sudden. How do I go around fixing it, using, etc?
The device is USB powered and the first test is to see if it opens on another computer and if not, another cable. If it does not work, the next thing to know is the probability of being able to get the unit operating again is very slim. Those devices use SMT components and they require very specialized service and diagnostic equipment. That is the reason that these drives come with back up software. You need to back up the back up. There is a slight chance that you may be able to remove the drive from the housing and plug it into a computer directly, of use a universal cable to activate it. Keep in mind that the drive has a lifespan.
4/20/2020 12:48:34 AM •
Verbatim...
Answered
on Apr 20, 2020
Dvd player keeps saying wrong region code
You only get to make four or five code changes and, for copyright reasons, thats it.
You can download Anydvd from Slysoft.com and it will nest in your desk top, and remove all dvd codes as you load. The dvds then run "Region Free"
They will copy with Dvd shrink and so your back ups are region free as well.
2/13/2020 2:23:24 PM •
Verbatim...
Answered
on Feb 13, 2020
Verbatim USB1T external drive
Assuming it’s powered on, do you hear the “usb” sound when you connect it to the computer? If not, try a different usb port, or a different cable. If you hear the sound, check for the disk in “computer management”. It may need partitioned or formatted.
3/27/2019 3:10:09 AM •
Verbatim...
Answered
on Mar 27, 2019
Verbatim memory stick can't unhide files
on properties on filing system go to view files and unhide files this will un hide every file on the computer so don't change the system files that are hidden, find the files that you are looking for and go into properties of the file and change them to un hidden. and press ok this will make them unhidden after you have done this to all files you need put the filing system back to original way your files will be seen but all hidden files will be back hidden.
6/29/2017 3:11:32 PM •
Verbatim...
Answered
on Jun 29, 2017
