20 Most Recent Brother Limited Edition LS2250PRW Project Runway Sewing Machine Refurbished LS2250PRW Questions & Answers
Turning wheel disconnected from motor?
I would try replacing the needle, as it may have got bent. I have had this happen and I was sure needle wasnt effected. when I changed needle it was fixed. The very tip of my old needle had a slight curve and wasnt connecting to correct spot on throat plate. make sure you have needle in highest position and that stitch selection in turned back to straight stitch.
11/8/2013 10:10:46 PM • Brother Limited... • Answered on Nov 08, 2013
Straight stitch is very loose and unable to fix it. tried every thing i think of
try adjusting the top thread tension and see if that help the stitchhere is a free quik start guide, just click on the linkhttp://www.brother-usa.com/ModelDocuments/Consumer/Quick%20Setup%20Guide/QSG_LS2250PRW_EN_2732.PDFand here is a free manualhttp://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_LS2250PRW_ENES_2733.PDF
11/20/2012 4:44:38 PM • Brother Limited... • Answered on Nov 20, 2012
2answers
My Daughter gave me a Brother Super Galaxy 11 model 895 but She does not have the hoop can any one please help me to locate one please. Hope someone can help Thanks in Advance. Judith
These can be easily found on Ebay Look carefully and make sure it will fit your machine!! Cheers, Embroidery Services San Diego, CA
2/6/2023 12:54:07 PM • Brother Sewing... • Answered 2 hours ago
Pedal on Brother XL-3200 has to be pushed far before engaging, making a grrrrrr noise before catching. Then machine will sew. But to fast for me to catch. Is it the pedal needs replacing?
t's possible that the pedal for your Brother XL-3200 sewing machine needs replacing. The issue you described with it needing to be pushed far before engaging and making a grinding noise before catching, could indicate a problem with the pedal mechanism. It's always a good idea to consult a sewing machine repair specialist to diagnose the issue and determine the best solution. They may be able to repair the existing pedal, or recommend a replacement if necessary.
2/6/2023 12:07:28 AM • Brother Sewing... • Answered 15 hours ago
Embroidery machine thread getting stuck!
The error message "Check and rethread the upper thread" on your Brother PE550D embroidery machine can be caused by a few different things. Here are some things you can try to fix the problem:
  1. Make sure that the thread is loaded correctly and the thread guides are properly adjusted. Refer to the manual or the threading diagram on the machine for specific instructions.
  2. Check the tension of the upper thread. The tension should be adjusted according to the type and weight of the fabric being used.
  3. Check the bobbin case and make sure it is loaded correctly and the tension is adjusted properly.
  4. Clean the bobbin case and the race hook, and make sure there is no lint or debris that could be causing the thread to bunch up.
  5. Check the needle, make sure it is the correct size and type for the thread and fabric you're using, and that it is inserted correctly and tightened securely.
  6. Inspect the silver arm on the left and make sure it is not bent or damaged and that it moves freely.
  7. Make sure that the presser foot is in the correct position and that the presser foot lever is in the proper position.
  8. If the above steps do not resolve the issue, it may be best to take the machine to a professional technician or contact the manufacturer for further assistance or service.
It is important to note that, the above steps are general troubleshooting steps, and the actual problem can be caused by different things, so it is best to consult a service manual for your specific Brother PE550D embroidery machine or contact the manufacturer for more detailed and accurate information.
1/23/2023 12:57:39 PM • Brother Sewing... • Answered on Jan 23, 2023
Brother 600ul overlocker, where do I out oil?
I searched it but this is all i could find and this is just general info not specific to your brother machine ... there are several services that have manuals for a small charge and you might contact the Brother company and request one. or at least ask them the question .. sorry i wasn't more help my rule of thumb is one small drop here and there from time to time doesn't hurt a thing just be careful it doesn't get on your fabric https://www.youtube.com/watch?v=h-yJ5PjYJL8
12/17/2022 8:36:57 PM • Brother Sewing... • Answered on Dec 17, 2022
Presser foot on Brother sewing machine vibrates and moves all over the place. Won't show straight.
sounds like a bad place on the screw thread. see if the tightening screw will go all the way on without a foot in place if not then try adding a small thin washer (one that fits the screw) and see if that fixes it.
12/13/2022 2:10:50 AM • Brother Sewing... • Answered on Dec 13, 2022
How to fix a Brother BM2800 broken spool spindle please?
The best parts suppliers are in this link. https://www.google.com/search?q=Brother+bm2800+parts .,.
12/9/2022 1:25:07 AM • Brother Sewing... • Answered on Dec 09, 2022
Brother CS-8150, "F04" what does it mean? I don't know what to do
make sure your foot peddle is fully pluged in. It's a foot pedal error code. Try unpluging your foot pedal and start the machine if it works without the foot pedal have the foot pedal repaired or replaced.
12/2/2022 6:14:54 PM • Brother Sewing... • Answered on Dec 02, 2022
2answers
How to find brother sewing machine ZZ3-B982 user guide?
Brother has extensive website and customer service. If you go to their site for your country and put in your model number, they'll tell you if they can get you a manual. Most are just downloads.. very easy. I'd give you a URL but I don't know where you are located. They have fabulous customer service, so try there first.
11/18/2022 2:27:35 PM • Brother Sewing... • Answered on Nov 18, 2022
Brother 546D Overlocker. Where can I buy the needles for an overlocker model 546D please.
Question edited for clarity, again. 'Make model (what it is)'. Question moved to Brother Sewing Machine again :>) Hello again Ceri The first company in the link are the one for all your sewing spares of accessories. Simply the best there is. https://www.google.com/search?q=Brother+546D+needles ..
11/16/2022 11:52:20 PM • Brother Sewing... • Answered on Nov 16, 2022
Why won't my bobbin fill when spinning on the winder?
You have to either tie it to a side hole in the bobbin, or do about 6 turns by hand first otherwise it just slips.
11/15/2022 1:23:33 AM • Brother Sewing... • Answered on Nov 15, 2022
Brother Limited Edition LS2250PRW Project Runway Sewing Machine Refurbished LS2250PRW Logo
7 questions posted
Top Brother Sewing Machines Experts
David Shaub
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Brother Sewing Machines
Most Popular Question
turning wheel disconnected from motor
  • Sewing Machines
