20 Most Recent Bazooka ELA300.1 Car Audio Amplifier Questions & Answers
My amp just stopped working the other day while i
blown fuse in amp or blown transistors in amp might check ground but i dont think thats it make sure no paint in the way on ground
5/17/2010 4:27:27 AM • Bazooka ELA300.1... • Answered on May 17, 2010
My amp is draining my battery, but still seems to
No doesnt sound defective if it works, but your alternater may not be powerful enough to maintain both your battery and car needs as well as power your amp. Best idea would be to look into getting a different alternator with a higher output.
2/4/2010 10:33:52 AM • Bazooka ELA300.1... • Answered on Feb 04, 2010
Heats up
It's normal for amplifiers to heat up during normal operation. If you power up the amp and let it idle (no audio) for about 5 minutes and it remains cool, the heating (when listening at high volume) is likely perfectly normal.
let me know if you have any other questions.
12/19/2009 10:42:49 PM • Bazooka ELA300.1... • Answered on Dec 19, 2009
My protection mode red light comes on right when i
Check your ground most definitly!, Replace it if needed. Check your remote wire and power wire as well. And if none of this works, then you are having internal issues.
9/1/2009 10:42:05 AM • Bazooka ELA300.1... • Answered on Sep 01, 2009
Csa300.1 bazooka 500 watts
sounds like you may have blown your sub...sheck the spyder inside of it and see if it is stiff..if the speaker doesnt seem too responsive when you press on it, its probably blown...
8/1/2009 9:12:58 PM • Bazooka ELA300.1... • Answered on Aug 01, 2009
2answers
Whats wrong??
you should check the remote wire bc you will get power to your amps if its not hooked up but you wont get any music!
3/6/2009 11:42:13 PM • Bazooka ELA300.1... • Answered on Mar 06, 2009
Red Led Light on My Bazooka Ela300.1
Your amp went into a " Protection Mode "
this happens if you have blown something inside like a IC or something... if the amp have been dropped or bumped then its very likely to happen ... Check and see if your fuses are ok, if not then it would be best to let it be checked by a expert if its a IC or a cap inside
Cheers
12/19/2007 8:12:47 AM • Bazooka ELA300.1... • Answered on Dec 19, 2007
0answers
Bt8250d is cutting out
Loose connection or your power cable and earth cable to your amp are not a heavy enough gauge.
11/30/2014 4:34:44 PM • Bazooka Car... • Answered on Nov 30, 2014
0answers
0answers
0answers
Speaker Fried, is my Amp toast too?
You are sending TOO much power to the speakers, Replace the speakers and then get a much smaller amp that is within the ratings of the speakers. ACTUALLY you should get an amp that is aboout 1/2 the total rating of the speakers.
You should ALSO procure a sound meter to verify the sound level is within safe limits. If you insist upon abusing your ears with too high a sound pressure, be ready to buy hearing aids at a VERY young age.
You also need to know that the enclosure of the speaker plays a part in keeping the speaker from tearing itself to pieces.
MANY of the auto sound system installers are hacks that don't do it right and you see what happens to your expensive equipment!
Using even a Radio Shack sound meter properly will protect your preciuos hearing for later life.
12/22/2009 9:19:21 PM • Bazooka Car... • Answered on Dec 22, 2009
Bazooka amp
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, do the following. I'll assume that you've checked the amplifier's on-board fuses.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it remains in protect mode, the amp almost certainly has shorted output transistors and will need to be repaired.
6/15/2008 6:52:48 PM • Bazooka Car... • Answered on Jun 15, 2008
How can I free down Elipse AVN1106D CD driver software?
it is not a computer but is CAR sound systems. the answer is ask the maker for support. read post 10 https://www.pakwheels.com/forums/t/eclipse-avn1106d-map-disc-required/226389
5/17/2024 12:20:07 PM • Car Audio &... • Answered Yesterday
2004 Lincoln Navigator (Canada) 6-cd changer stereo died. I want to get an after-market stereo but not sure what else I need? Which wire harness I need, connector, adaptor or installation kit?
Like for like. Go to a breakers yard. The audio system is an extension of the Body Control Module, part of the computer system and is used to Audio Alerts, Chimes etc. that play through the speakers. If you replace it with a completely different unit, the BCM won't understand the data. A company like Crutchfield will guide on you what _might_ work, and they will also supply harness connectors. It needs to be specific. https://www.google.com/search?q=2004+Lincoln+Navigator+(Canada)+6-cd+changer+stereo ..
5/12/2024 12:31:47 AM • Car Audio &... • Answered on May 12, 2024
How to set time and alarm in KADIO KD-3810N
Insert Batteries: First, insert 2 AA batteries into the back of the clock. Access Time Setting Mode: Press and hold the Mode button for 5-10 seconds until the clock enters the setting mode. Adjust Time: Once in the setting mode, use the Up and Down buttons to change the time, month, and date. Press the Mode button to cycle through the different settings. Set Hour and Minute: When you reach the time setting, adjust the hour and minute using the Up and Down buttons. Press the Mode button again to move to the next setting (e.g., month, date). Exit Setting Mode: After setting the time, press the Mode button to exit the setting mode.
5/10/2024 4:28:29 PM • Car Audio &... • Answered on May 10, 2024
Bazooka ELA300.1 Car Audio Amplifier Logo
12 questions posted
Top Bazooka Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Bazooka Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Bazooka Car Audio & Video
Most Popular Question
protection mode red light comes right
  • Car Audio & Video
