20 Most Recent Staples SPL-P500 Printing Calculator Questions & Answers
Try making a point and feed it in the right place, the feed roller which is only about 1/2 inch wide should pick up the paper.
Staples SPL-P500... | Answered on Nov 07, 2017
Your calculator is fine. It is an adding machine first, so it uses adding machine logic and you hit the star button to print the total on the tape. The equals sign is only used when multiplying and dividing.
Adding machine logic is as follows:
5+ total 5
3- total 2
7+ total 9
* print out total
Good luck,
Paul
Staples SPL-P500... | Answered on Sep 14, 2016
Try calling the company
Staples SPL-P500... | Answered on Oct 24, 2013
That is because when you turn it off the cooling fan stops and if you have been using it a lot, the heat immediately builds up and it trips the overheat switch.
If should restart after about an hour. Unless it is an industrial shredder, you should use it no longer that 5 minutes. Shred a little and often.
Staples Office... | Answered on Apr 28, 2020
IF YOU LOOK INTO THE SLOT WHERE YOU FEED THE PAPER...GET A FLASHLIGHT ........IN THE MIDDLE OF THE SLOT YOU WILL SEE A TINY SWITCH. THAT THING SOMETIMES GETS GUMMED UP WITH GLUE FROM ENVELOPES AND SUCH... TRY SOME WD-40 ON THAT SWITCH... WITH THE MACHINE UNPLUGGED PUT PAPER IN THE SLOT TO MOVE THE SWITCH SO THE WD-40 CAN LOOSEN UP ANYTHING .... THEN TRY BLOWING AIR IN IT....
ARE YOU SURE THAT THE TOP OF THE SHREDDER IS SITTING FLUSH WITH THE PORTION IT RESTS ON??? THAT COULD ALSO MAKE IT NOT WORK..... OR IF THE BASKET NEEDS EMPTYING THE TOP WONT REST FLUSH ON THE BASKET.
Staples Office... | Answered on Feb 18, 2020
ask google or your local home improvement store
Staples Office... | Answered on Nov 23, 2019
Staples SPL-P500 Printing Calculator Logo
18 questions posted
Top Staples Office Equipment & Supplies Experts
Marvin
Marvin
Vernon Taylor
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Staples Office Equipment & Supplies
Most Popular Question
doesnt equal button work when additions
  • Office Equipment & Supplies
