20 Most Recent
Swingline Optima 45 Electric Stapler Questions & Answers
Why doesn't it staple?
Disassemble the stapler sufficiently to expose the staple "stick" advancing mechanism and repair it to restore pressure against the stick to advance it.
How to take apart Swingline SpeedPro 45 stapler? Model S7042141
To disassemble a Swingline SpeedPro 45 stapler (Model S7042141), follow these steps:
- Open the stapler and remove any staples that may be inside.
- Locate the two small screws on the bottom of the stapler, near the front.
- Use a Phillips head screwdriver to remove the screws. Be sure to keep them in a safe place.
- Gently pry apart the two halves of the stapler. You may need to use a flathead screwdriver or other tool to help separate the pieces.
- Once the stapler is open, you can access the internal components, including the spring, magazine, and stapling mechanism.
Note: It is important to exercise caution when disassembling any tool or device, as parts may be under tension or spring-loaded. If you are unsure how to proceed, consult the manufacturer's instructions or seek the assistance of a professional.
