20 Most Recent
Bob Mackie Mackie M-1400i Power Amplifier Car Audio Amplifier Questions & Answers
AMp does not display any LED read out
Amps have a part inside that is made to keep the channels equal. The problem is that when there is nothing hooked up to the second channel, then this goes bad and goes into protect. It is really hard on an amp to use just one channel.
Mackie 1400 overload lights on
hey Ron
use a larger ground wire it will stop the overload you may have to place it somewhere new but its the size of the wire that trips the overload feature too small and amp will go and protect itself (bigger ground better sound)
hope this helped
Mackie 1400i Shorts out about 75% of volume when bridged
Hi, the problem is probably a bad solder. I don't know how this amplifier is made, but if the 2 channels have this problem together you should start by re-solder properly the components of the power supply especially the auxiliary power supply for the preamp. If it's a class H amplifier, check the hi + and - .
Bernard
Help with code radio for my nissan pp2787h
The radio code is a security feature that's meant to deter theft, and it's unique to each vehicle. If you've lost your code, you'll need to contact a Nissan dealership or service center and provide proof of ownership. They should be able to help you retrieve the code. Please do not attempt to use codes from the internet as incorrect attempts may lock your radio.
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
No sound from wireless headphones in a toyota sienna
First thing to do is check to make sure that the batteries are properly charged.
Second, make sure that you have a clear line-of-site to the IR transmitter. Infrared (IR) works the same way that your TVs remote control works - if the signal is blocked, then you will not hear any sound.
Third, make sure that you are in the rear seat of the vehicle when listening to the sound. The IR transmitter only transmits to the rear seat, so you will not hear any sound if you are sitting in the front seats. This is a common problem that i see.
Lastly, make sure that the heapdhones you purchased are compatible with your 2006 2007 2008 2009 or 2010 Toyota Sienna. Remember that some older models require RF headphones, not IR headphones. I checked http://www.audiovideo2go.com for compatibility before I purchased my headphones. They have a useful listing of all the headphones and models of vehicles they are compatible with.
