20 Most Recent Nintendo Donkey Kong for Game Boy Color Questions & Answers
Maybe your game is just dirty.
Try using a Q-tip to clean the metal parts that look like piano keys.
Hope this helps :)
Nintendo Donkey... | Answered on Sep 01, 2011
I am guessing that the battery needs to be replaced in your gameboy advance SP and after 500 charges the battery will only be 70% working and temperature can also effect the battery too. If the light is flickering green and red at the same time that is also an indicator that the battery is going bad and has to be replaced.DkOldies and Lukie Games and East Starland games sell replacement batteries for gameboy advance SP's.
Nintendo Video... | Answered on Mar 02, 2021
I don't think that you can connect a wireless gamecube controller to an android tablet it is not compatible at all.
Nintendo Video... | Answered on Feb 28, 2021
The vertical white coloured bar in the middle of the TV’s screen is caused by the power dropping during a DRAM refreshing and an essentially also an inefficient power filter and the power filter needs to be replaced and the power filter is going bad. It can also mean that the power jack is bad and the voltage regulator and the capacitors are going bad too and all need to be replaced.
Nintendo Video... | Answered on Feb 25, 2021
  1. Power cycle the Wii by unplugging the console and wait about five minutes and then plug it back in.
  2. Try creating another profile connection by going through the connection process again.
  3. Check for anything that is interfering with the WIFI connection for your WII console . The Wii console should be in an open area without anything blocking the signal.
Nintendo Video... | Answered on Feb 24, 2021
Wii Error Code 51330 and 51331, and 51332 means incorrect WiFI password and the wrong password was typed in.
Nintendo Video... | Answered on Feb 23, 2021
Your Wii remote is broken or the that one button is broken and you should buy a new WII remote.
Nintendo Video... | Answered on Feb 22, 2021
The capacitors have gone bad inside of your N64 console and need to be replaced and or that the ac adapter has gone bad then. I would try buying a new ac adapter to see if that helps and also replace the capacitors inside of your N64 console as well and the red light flickering should stop then.
Nintendo Video... | Answered on Feb 18, 2021
The plastic part inside of your WII's disc drive that holds the disc's in place is going bad and needs to be replaced.It could also mean that the disc drive is starting to go bad and is wearing out and will need to replaced for your WII console.
Nintendo Video... | Answered on Feb 03, 2021
The problems here would be related to parts on the Nintendo 64's motherboard, maybe also the capacitors too inside of the console it's self . Its also very possible that the heat sink has gone bad and the power supply is going bad inside of the console the ********* piece where the ac adapter attaches too they would be complicated repairs to do you would be better off purchasing a new Nintendo 64 console than to repair the current one that you have If you live somewhere where there are not a whole lot of choices are available then you should just purchase a new one
Nintendo Video... | Answered on Jan 23, 2021
I am guessing that maybe there is something internally wrong with your gamecube console the hardware inside of your gamecube console is having issues then or the fan might not be working anymore so it keeps on showing up an error has occurred and it needs a new fan. If the disc look fine and work on a Wii console then there is something wrong internally with your gamecube console and it needs to be repaired. It would be cheaper to buy another one from Lukie Games or DKOldies or East Starland Games or JJ games or you can buy a Wii and play on a Wii console.
Nintendo Video... | Answered on Jan 21, 2021
It could be due to having a bad video chip inside of the console so it goes into slow motion or the jumper pack or the expansion pack is starting to go bad. Or the console needs to be cleaned out too. The coloured Nintendo 64 consoles seem to be made lower quality than the original black N 64 consoles are. Try a new expansion pack and a new jumper pack then to see if it makes a difference. You needs a 4.5 mm bit game tool to open up an N 64 console. DK Oldies and East Starland games and Lukie games and JJ games sells those and jumper and expansion packs for N 64 consoles.
Nintendo Video... | Answered on Dec 24, 2020
I am having the same problem with my super Nintendo console not having the red power light coming on. It could be the ac adapter that is causing your SNES console to not be turning on. You could try a new SNES ac adapter to see if it works or not. If your SNES console still is not coming on with a new ac adapter it maybe be the fact that your console is not working anymore and it would be more cheaper and easier to buy another SNES console than to fix the current one that you have. Lukie Games and DKOldies and East Starland games and JJ games have SNES consoles.
Nintendo Video... | Answered on Oct 08, 2020
My N 64 console goes in slow motion as well too. It could be the ac adapter might be causing this problem here so try a new ac adapter to see if it solves the problem or it could be the power outlet as well that is not putting out the proper power to the console or it needs to be cleaned out. Or the video chip went bad and the slow motion is occurring. The jumper pack or the expansion pack could be starting to go bad and needs to be replaced and it is warning you that the jumper or the expansion pack is going bad and will stop working anytime and the game will freeze and then turn all black and then blank out on you and you will go to the screen on the TV after that. Sometimes the expansion and the jumper packs can quit working with no warnings at all to let you know. Or it can say on the TV screen expansion pack or jumper pack is needed. I have tried a new expansion pack for my N 64 console and it is working fine again it could just be that.
Nintendo Video... | Answered on Aug 30, 2020
Yes it does, I also use it on the Wii U. I switched the Wii to wireless and put the adapter in the Wii U, and it works just fine.
http://www.nintendolife.com/forums/wii-u/does_the_nintendo_switch_wired_lan_adapter_work_with_the_wii_u
Nintendo Video... | Answered on Apr 02, 2020
https://www.google.com/search?source=hp&ei=c6F3Xpa1H434aZyjvKgI&q=Does+anyone+know+how+to+fix+Nintendo+switch+that+wont+charge+or+turn+on%3F&oq=Does+anyone+know+how+to+fix+Nintendo+switch+that+wont+charge+or+turn+on%3F&gs_l=psy-ab.3...2272.2272..3816...0.0..0.223.423.2-2......0....2j1..gws-wiz.....6..0i362i308i154i357.ZALYeJKMx6g&ved=0ahUKEwjWurPazq7oAhUNfBoKHZwRD4UQ4dUDCAU&uact=5#kpvalbx=_gKJ3XprADoGOlwT9wq7oDg30
Nintendo Video... | Answered on Mar 22, 2020
eBay may have several listings with instructions. You might try contacting the seller to see if you could obtain a copy of the instructions without purchasing the entire box.
Example:
https://www.ebay.com/itm/Vintage-Interact-V3-Racing-Wheel-and-Pedal-Nintendo-64-Playstation-Game-System-/333533215793
Nintendo Video... | Answered on Mar 15, 2020
Nintendo Donkey Kong for Game Boy Color Logo
2 questions posted
Popular Products
Top Nintendo Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Aron
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
View Most Popular
  • Nintendo Video Game Consoles & Games
Most Popular Question
donkey kong gameboy game
  • Video Game Consoles & Games
